ACT organic clutch installed on 335i
03-25-2012, 01:52 PM | #1 |
36
Rep 332
Hi all,
I'd like to share a few comments after installing my new clutch on my car. The stock car started slipping a few months ago. First on map 2 and meth and then on map 1 without meth. At the beginning it was not very noticeable at all until the last month. When I was flooring it on 2nd or 3rd, revs were climbing by 1500-2000 before acceleration started. But when the clutch and flywheel were getting warmer, the slipping dissipated. It looked OK until I made a few pulls with my friend (FBO no meth) and pulled only 1/2 car away from 60 to 260 kph. A friend of mine gave me a slightly used ACT pressure plate so I bought a 6-puck disk to make the swap. Fortunately, I bought a new set of pressure plate and organic disk. The 6-puck on my friend's car is not driver-friendly. You need to rev the engine up to 1800 rpm to move the car on cold start and makes a rubbing metal noise when it engages. It might sustain more torque than the organic but I don't use my car only for street-racing as he does. Anyway, after purchasing all the components needed (pivot bearing, throw-out bearing, bearing bracket, aluminum screws -can be used only once after gearbox is removed- and pressure plate screws) I drove to a local shop to perform the swap. It took around 5 hours to complete the swap. It needs a lot of time to remove the exhaust, the underpanels, the gearbox, to clean the flywheel and put back the transmission. Here are some pictures: Throw-out bearing on the clamp: The flywheel. It's in good condition so no resurfacing was needed. And yes, it has 6 screws so I can fit a 1M flywheel in the future: The ACT pressure plate: Comparison of the old stock clutch disk and the new ACT organic disk: The clutch disk and the pressure plate installed: My stock pressure plate (up) vs my friend's used ACT pressure plate (down). As you can see, the stock pressure plate was destroyed due to slipping (black marks): The stock pressure plate springs are burnt to death. The small springs make the pressure plate self adjusting (will explain later): Stock pressure plate vs used ACT: Impressions: The very first time you get in the car the clutch feels awful. What a bad impression. The clutch pedal is excellent. It's a matter of time before you get used to it. After 1 hr of driving the clutch feels normal. No, it doesn't get easier to push, your left foot gets used to it. After that I drove my mom's E46 and I almost ribbed off the clutch pedal lol. The pedal feels like normal for the first 50% of the pressing distance, then it gets harder to push. ACT claims it is 30% harder, I would say 50-60% harder. Engaging is very smooth and feels stock. Engagement point is 5-10 mm from the floor mat compared to stock on which engages 20-30 mm from the mat. No clutch stop is needed. No harsh engagement at all. All sports cars should feel like this. I've done 100 kms with the new setup, need to perform some more urban driving the next days. After get 1000 km on the odometer I'll start flooring it. Many thanks to Jeff@topgearsolutions for purchasing the clutch disk. You cannot find people so cooperative and so communicative. I wish every vendors/sellers were like him. He shipped the clutch the very next day and I got it 5 days later. Thank you Jeff. Edit: you might also find another review here from tscdennab: http://www.e90post.com/forums/showthread.php?t=650301
03-25-2012, 01:56 PM | #2 |
36
Rep 332
Damn, I forgot it. The small springs on the stock pressure plate make it self-adjusting. Which means that the force needed to push the clutch pedal is the same all the time. ACT clutch disk is old-school and doesn't utilize those springs. That's why the clutch pedal feels softer at the beginning and then it gets harder
03-26-2012, 03:02 AM | #8 | |
263
Rep 2,561
Haven't had such a good laugh in a long long time. Some people...you really wonder how they're even able to dress in the morning, let alone drive a car. Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
03-26-2012, 11:09 AM | #10 | |
Lifelong Cynic
11
Rep 167
However, are you noticing any chatter/shudder on engagement? You stated "no harsh engagement", so maybe not. I had significant shuddering on engaging 1st when it was breaking in. The only way to be perfectly smooth was to very gradually let the pedal out without giving any gas at all. It has gotten better over time, but there is still some non-stock chatter on engagement. ACT said this can be normal, so I did not worry too much about it, but if you id not experience it at all, then it does concern me somewhat. I had mine installed by a respected BMW shop. At first I thought it might have been that the stock DM flywheel was worn/damaged, but the installer claims it did not show signs of needing resurfacing or replacement. I assume since you don't mention it that you did not do anything to the flywheel and are on the stock DM one? I'm glad to hear that you think the 6-puck is not DD friendly...I was second guessing my decision to go with the organic street disc since the torque rating, albeit conservative, is considerably less than where I will be at in a couple of months when I go FBO/tune |
03-26-2012, 11:41 AM | #11 | |
263
Rep 2,561
Alpina_B3_Lux
03-26-2012, 01:32 PM | #12 | |
36
Rep 332
A few questions: -- Did you change the throw-out bearing as well as the bearing clamp? -- Has the installer lubricated the clutch disk spline as well as the gearbox primary axle housing? This is an aluminum cone around the gearbox aluminum primary axle (the axle with the spline). The throw-out bearing moves along that cone up and down during engagement/disengagement. I'm with the stock DM flywheel, is was not damaged at all, only the stock disk was worn out from NLS shifting and it couldn't handle the extra FBO+meth power. The 6-puck disk is not driver friendly. You can hear a sound from my friend's car like a metal click or like hammering a piece of iron. In the future, I'm planning for a turbo upgrade. I'm sure the organic disk will not be able to handle that power output but it is OK for now. It is the best choice if you are planning to getting FBO+meth
03-26-2012, 01:34 PM | #13 | |
36
Rep 332
Thanks for sharing, FX300 was the next option along with HPF feramic clutch but it was expensive for the time being. Has the FX300 organic disk or is it composite/ceramic compound?
03-26-2012, 01:49 PM | #14 | |
Lifelong Cynic
11
Rep 167
03-26-2012, 02:01 PM | #15 |
36
Rep 332
For your 2000 miles you should have breaked in your disk. It's very difficult to have a defective clutch disk since all products are under quality control from companies like ACT.
It is quite difficult removing the tranny on a xi and not cost-worthy. In my opinion, flywheel surface has nothing to do with the noise. If the surface was damaged, the new disk would slip. It sounds like lubrication noise but can't tell for sure. I wish I could help someway
03-26-2012, 04:07 PM | #16 |
36
Rep 332
I just returned from a short ride. I tried to make the clutch disk chutter by any means. I tried releasing the clutch pedal on first gear without revving the engine until the engine stopped. No chatter at all.
I rember form the stock clutch that there was some chatter when I was shutting off the engine without pressing the clutch pedal. That was because of the worn trow-out bearing. Everything looks fine with my new clutch
03-26-2012, 05:20 PM | #17 |
Lifelong Cynic
11
Rep 167
It's not a noise, it's a tactile sensation, a feeling. The car vibrates or "shudders" during clutch engagement. It was very pronounced before, now it is minor but still noticeable.
03-26-2012, 05:31 PM | #18 |
70
Rep 2,626
It happens only in low situations right?
'18 F80 M3 Comp 6MT - Stock
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 |
03-26-2012, 06:11 PM | #20 |
70
Rep 2,626
I have your same problems except it only happens in reverse. in first gear it's very hard to do. Now it got much better even though I only have a 100 miles on it.
I replaced everything including the flywheel btw. I'll talk with my shop tomorrow to see what they come up with. Everyone is telling to give it some time... we'll see I guess. I hate it when I get weird issues especially after having paid around 2400$ for parts+install
'07 E92 335i 6MT- HP650, inlets/outlets, ER FMIC, VRSF CP, LPFP stg2, CSF rad, 'is Aux rad, ER OC, Ohlins, M control arms, eibach front sway bar. '05 C55 AMG SOLD - '22 Tesla M3P | '10 E92 335i M, 6MT | '07 E90 335i, PTF COBB E50, FBO, HFS4 Last edited by marv85; 03-26-2012 at 06:33 PM.. |
03-26-2012, 06:31 PM | #21 | |
Lifelong Cynic
11
Rep 167
I feel you on the price...not a cheap job on these cars Sorry if we hijacked your thread stratos! |
03-27-2012, 02:38 AM | #22 | |
263
Rep 2,561
Alpina_B3_Lux
