2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs Rock Chip
      03-25-2012, 12:40 PM   #1
BigP535I
Cambodia
18
Drives: F10 AW Mtech
Rock Chip
I got a nasty one on my hood, pretty much got to the metal....anyone have any suggestion to patch it up? Anyone here ever used that Drcolorchip product, does it work as advertised?
      03-25-2012, 04:11 PM   #2
snj1013
87
Drives: 2011 528i
What color is your car? Just get some touch up paint, slowly and carefully "fill" the chip up with paint. This may take several or more coats. Once the chip is filled, you can then wet sand the touched up area back down so that is flat with the hood's paint. Finished off with some polish, and off you go. Depending on the color of your car, you might start filling the chip with colored paint, and finish off with clear. Some metallics have alot of mica that floats to the top and the color will be affected when wetsanding.
      03-25-2012, 07:45 PM   #3
BigP535I
Cambodia
18
its alpine white
      03-25-2012, 08:19 PM   #4
snj1013
87
Drives: 2011 528i
White should be easy. You can either just use the Alpine White touch up or white topped with clear. Autozone sells the sandpaper (1500-3000 grit).
If you're uncomfortable with sanding the paint on your car, you might want to find a detailer or talk to your dealer. Your dealer most likely has a mobile paint repair guy that could handle it.
5post
