F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > winter tires..
Extreme Powerhouse
      03-24-2012, 09:37 PM   #1
G_Metric
Drives: a Few
winter tires..
Anyone have winters on their new 3 yet? I've gotta get some for my son. What would you recomend?
      03-25-2012, 10:56 AM   #2
E90Fleet
South Africa
1312
Drives: BMW
The BMW recommended winter tires for the F30 are:
17"
Bridgestone Blizzak LM32 Runflat 225/50/17
Pirelli W210 Sottozero II Runflat 225/50/17
Dunlop SP Winter Sport 4D Runflat 225/50/17
18"
Continental TS 830P Runflat 225/45/18
Pirelli W240 Sottozero II Runflat 225/45/18
BMW if you are reading, I need a job, Please.
      03-25-2012, 08:31 PM   #3
shoptb
shoptb's Avatar
Drives: '19 G01 X3 m40i
Continental ExtremeContact DWS (non-run-flats) ... use them on my E92 and they are amazing.
Delivered --> '21 G01 X3 M40i, 8SA, Sunstone Metallic with Cognac Vernasca, 22Z, ZDA, ZDB, ZPK, ZPP w/ 4HA, ZPX, 2VF, 3AC, 4K1, 688, 6NW, 5DF
Past --> ?19 G01 X3 m40i, 15 F33 328xi, 8SA, '13 F30 328i, '08 E92 335xi, '95 E34 530i, '88 E30 M3
      03-25-2012, 11:29 PM   #4
G_Metric
Drives: a Few
if you have non-runflats are you SOL if you get a flat?
      03-26-2012, 10:18 AM   #5
shoptb
shoptb's Avatar
I have a can of fix-a-flat, a AAA card, and a cell phone. Not sure that you need much more.
      03-26-2012, 10:45 AM   #6
G_Metric
Drives: a Few
I'd put run-flats on for sure. If fix-a-flat won't fix it I don't know what AAA would do without another wheel and tire.. seem like a lot of hassle..
      03-26-2012, 11:23 AM   #7
shoptb
shoptb's Avatar
I think it's definitely up to individual preference. When I get my F30, the first thing I'm doing is taking the run-flats off and putting on non-run-flat tires. I hate run flats! They're not nearly as good of a tire. But, I suppose that there are some concerns....but with 24/7 roadside assistance, do you really need to worry about it?
      03-26-2012, 11:40 AM   #8
Shuttlegoose
26
Drives: f30 328, e36 m3
Yeah I'm not so sure I want to put run flat snow tires on either. I guess time will tell. Hopefully by October tire rack will have some packages < 1100$
      03-26-2012, 12:24 PM   #9
wdlv
wdlv's Avatar
Drives: 2019 X5 40i M Sport
Speaking of Tires - Are you installing TPMS in your aftermarket tires?
Hey all,
Speaking of tires, are you installing Tire Pressure Monitoring System in your aftermarket tires? Tirerack is indicating that you must install 433MHz Tire Pressure Sensors if your vehicle has it (some states require this to pass inspections).
Are there any downsides to not installing the TPMS? Obviously you can't monitor the tires via iDrive and you have to keep track of tire pressure manually. Any other down sides?
I mean you could take out the ones from your Summer wheel set but that just makes for more work and isn't really a solution. Just considering my options for next winter. It's a good thing I don't need to worry about this for this season.
Comments, welcome.
      03-26-2012, 01:00 PM   #10
DMafia46
Hates Posers
13
Drives: E46M3,335xi,Lambo,
Winters over bro
      03-26-2012, 01:04 PM   #11
MassBimmer
MassBimmer's Avatar
306
Drives: 2023 i4 M50
2009 BMW  [9.24]
Those are also all season tires, not winter tires
      03-26-2012, 01:26 PM   #12
Foodle
Drives: 2011.75 E90 M3
Originally Posted by DMafia46 View Post
Winters over bro
Silly Southern Hemisphere
      03-26-2012, 09:16 PM   #13
G_Metric
Drives: a Few
I just thought about it and I'm going to hold off until the fall, he can buy them in Canada - will save a lot of space on the move up..
      04-29-2012, 07:16 AM   #14
thedonva
Drives: Mini Clubman S
Does the beamer have a slot for a spare, my mini clubman does and I swapped out the run flats summers to all seasons after getting stuck?
      04-29-2012, 08:31 AM   #15
K.Ip
K.Ip's Avatar
Drives: F30
Originally Posted by wdlv View Post
Hey all,
Comments, welcome.
+1
curious myself
i think you get that "ding" noise in the car repeatedly
also does anyone know if 433MHz will work? specifically the ones from e9x?
      04-30-2012, 06:41 PM   #16
RASHID007
47
Drives: 2014 535d X-Drive
I would love to know the answer to this as well.
      05-01-2012, 10:10 AM   #17
RedlineSi
12
Drives: 2012 328i
Originally Posted by K.Ip View Post
+1
curious myself
I'm wondering this too. I didn't have them put in when I had a G37 and all you'd get was a warning light, but no dinging sound.
      05-02-2012, 06:46 PM   #18
_BMWnEwBiE_
Drives: 2012 328i
Continental (DSW) dry, wet & snow and people are really happy with the performance they get from those tires but the tire it self has a wear indicator after about 6-10k miles you lose W so now you are only good for Dry and wet another 20-25 you lose wet also after that you are only good for Dry weather so for a winter tire it is not a good idea.
I am all about Blizzak tires tried so many different winter tires Bridgestone was the best but i am definitely not putting RFL tires for winter and even may be for summer also.
In last 10 Years i used my spare tire 2 or may be 3 times that is it. other than that you are getting warned by the computer you have a low air pressure and all these tires don't go flat right away as long as you don't a slash or giant hole on your tire. And like they say you shouldn't be repairing your run flat tire anyways.
So they are saying every time you will be spending about $300 on your tire of course if your vehicle is xdrive than you are SOL because you need to change all 4 now.
My advice to you is just a carry an air pump in your trunk and pay attention to your TPMS you should be fine.
f30post
