BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > USA - Midwest / Rockies
EXXEL Distributions
      03-23-2012, 03:08 PM   #1
ChrisAW
Rear Admiral
ChrisAW's Avatar
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
STL/MO how to pass emissions/inspection with mods?
How do people in STL/MO deal with the emissions testing if you have deleted cats or supercharged? I've never really had a clear answer other than to convert back to stock for the test. A little rough to do with a SC...
MO stopped testing cars as old as my RX-7 was so I put it out of my mind.
Thanks!
--Chris
--2011 e92 M3
      04-18-2012, 03:14 PM   #2
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
I'm interested in this. I may have to move to MO/KS in the near future.
      04-20-2012, 10:24 AM   #3
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
When the time comes, I'm just going to put the Stock X-pipe back on. I know of a shop that does "Fast Pass"... but you still can't have check engine light on... When the time comes, i may go to them and see if it'll pass with my delete-R... not sure.
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3...
It all started with an RX-7 (FD).
      04-20-2012, 11:00 AM   #4
THE TECH
THE TECH's Avatar
307
I think and luckily for me if I have to move there, the county does not have smog checks. Are safety inspections just to make sure that the car is ok or do they scrutinize non-factory parts?
      04-20-2012, 11:12 AM   #5
ChrisAW
Rear Admiral
ChrisAW's Avatar
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
Basically if they see any semblance of a catalytic converter you are good to go.
--Chris
--2011 e92 M3
      04-20-2012, 11:13 AM   #6
THE TECH
THE TECH's Avatar
307
Is that assuming that you are in a county that requires smog or is that indicative of anywhere?
      04-20-2012, 11:17 AM   #7
ChrisAW
Rear Admiral
ChrisAW's Avatar
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
I think everywhere requires an inspection and they will check to make sure you have cats. They don't have to be working, but they have to be there.
--Chris
--2011 e92 M3
      04-20-2012, 12:22 PM   #8
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
They don't do Smog anymore in the MO... it's just OBD2 check and the visual inspection... If you don't have Cats, you can go to some place and ask for Fast Pass... they might do it... THat's what this shop in St. Louis does. They charge you 75$ for everything but it's in and out.
      04-20-2012, 12:24 PM   #9
THE TECH
THE TECH's Avatar
307
I like that idea. When did smog stop? According to the DMV site, it is still active.
      04-20-2012, 12:40 PM   #10
Boostin FD
Bored all the time
Boostin FD's Avatar
Drives: Batmobile
For cars 1996 and after, it's only obd2 plug... they do some scanning, make sure there are no faults and all the Emission stuff is operational.
We use to have that Gateway Clean Air program that acted like a Dyno with plugs for exhaust... however after number of engines getting damaged by people forgetting to turn the fans on or something, they canceled the program.
Cars before 1996 only require safety, cars after do the emissions and safety... but it's only that obd2 plug check thing.
      04-20-2012, 01:13 PM   #11
THE TECH
THE TECH's Avatar
307
Excellent news!
      04-21-2012, 02:35 PM   #12
Epacy2
Epacy2's Avatar
147
Drives: F85 X5M
2008 M3  [0.00]
2008 M3  [0.00]
It's based on zip code. I've lived in the STL area for 11 years and never had to do an emissions test.
m3post
