Real Wood Trim??
06-11-2007, 09:54 PM | #1 |
Evil Dictator
12
Rep 176
Drives: E93 space grey, jade grey int
Real Wood Trim??
Does anyone know if the wood BMW uses on their car is real wood???
I saw a picture of the backside of the centre wood trim and looks like plastic. But it could be that the wood is really thin. Anyone know? |
06-11-2007, 10:00 PM | #3 |
278
Rep 2,008
I believe it IS real wood. It is very thin and steamed to be made pliable.
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe (Past): 2016 F30 340xi M-Sport -2013 535i xdrive 2008 E92 M3 - 2006 E90 325i 2002 E46 325xi - 1991 E30 325i |
06-11-2007, 10:02 PM | #5 | |
7
Rep 307
Long story short....plastic, topped with probably 1/16' or 1/32" veneer of real wood topped with a clear enamal. So, yes its real wood if you consider 1/16" squashed between plastic real wood. Same trick used by all the luxo brands. |
06-11-2007, 10:30 PM | #7 |
278
Rep 2,008
06-11-2007, 11:07 PM | #9 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
It's a really thin piece of wood with on top of plastic with a clear resin coating (like those engineered flooring)
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
06-11-2007, 11:15 PM | #10 |
Trance Life
315
Rep 4,706
06-11-2007, 11:27 PM | #11 |
208
Rep 2,558
'07 Space Gray 335i coupe - R.I.P.
COBB ProTuned | AMS | CP-e | BMS | Quaife |
06-12-2007, 03:36 AM | #12 |
94
Rep 3,748
Drives: BMW 325Ci Individual
06-12-2007, 03:39 AM | #13 |
14
Rep 194
Oy...
A thin veneer of real wood is glued to a rigid substrate which is then molded to the actual foam plasctic trim piece. The wood veneer is then "clear coated" for protection. By the way, this is the same way that Bentley and RR do it as well; no regular production cars have used solid planks of wood for years. |
06-12-2007, 05:47 AM | #15 |
7
Rep 138
It's just like my old T-Reg Real thin piece of wood between the pieces of plastic and yes it can crack..
Better yet what about a leather sterring wheel? They just get worse and worse. Oh it's plether |
06-12-2007, 08:53 AM | #16 |
AC
95
Rep 2,387
It is real wood, covered by a material called "Acrylic". This material is harder and more expensive than crystal, usually reserved for high-end cosmetic bottles or jars.
Your Supreme Leader
06-12-2007, 08:58 AM | #17 |
pull my finger to get your kinder® surprise
148
Rep 10,455
it's real wood. But does it really matter? I understand the argument between leather and leatherette, both has its pros and cons. But fake vs real wood? would you die of embarrasment if your car's equipped with fake wood and people found out about it?
06-12-2007, 09:31 AM | #19 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
They all use real wood veneer. Iirc veneers are inherently safer than solid planks of wood for obvious reasons. Plastic backed veneers do not explode in a grenade of sharp splinters in the event of an accident. I am sure there are other reasonings like costs, weight etc. You can also see this by the differing burls/patterns from car to car.
I suppose it would've been easier to make things out of solid wood vs veneers...
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
06-12-2007, 10:23 AM | #20 | |
10
Rep 513
06-12-2007, 10:28 AM | #21 | |
156
Rep 10,411
all BMW's come with real wood
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
06-12-2007, 10:29 AM | #22 | |
156
Rep 10,411
