Metal Washer on Top Hat?
03-16-2012, 10:26 AM | #1 |
14
Rep 245
I replaced my top hat on the drivers side this weekend and also reinstalled the metal washer which came off my stock suspension. I took a look at real OEM just to confirm what the washer is actually for and it is not even on the parts diagram Does anyone know what this metal washer is or if i need to run it on my KW's? It looks exactly like the paper washer for the top hat except it is made out of steel and is about 4-5mm thick. The paper washer is number 5 in the diagram.
03-16-2012, 10:38 AM | #5 |
35
Rep 781
I would. If the car came with it I would leave it. If you go into the xi section there have been a few people that have kept it off to lower the front end further but since you have key's you can lower as much as you want.
My thought is that it was put there for a reason. |
03-16-2012, 10:40 AM | #6 | |
35
Rep 781
03-16-2012, 10:48 AM | #7 |
14
Rep 245
03-16-2012, 11:01 AM | #9 | |
84
Rep 777
Maybe on the AWD it's a metal collar...
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD . M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings . BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts . Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete |
