Blackberry 8100 and BMW Bluetooth
06-10-2007, 09:56 AM | #1 |
Rep 29
Hi,
Has anyone managed to sync over their full address book from a Blackbery 8100 to an e93. i have the ProSatNav system fitted with the Bluetooth telephone prep with telematics. The car sees my Blackberry and I can make and receive phone calls, but my address book only gets as far as the letter E - not a lot of good. I have ab out 200 entries. I know that the Blackberry 8100 is designated Limited functionality, but i would have thought that if it takes part of the address book, it would take it all. I do have an older SE K800i, and that has worked perfectly, but I would rather use my 8100, and dont really want to have to keep swapping the SIM Card. Thanks for and advice or help Alex
E93, Black Sapphire with Cream Leather and Aluminium Trim | Automatic | Pro SatNav | Logic 7 | Bluetooth | Heated Seats with Lumbar support | Comfort Access | Climate Screen | PDC | Adaptive Headlights | Rain Sensor & Auto Light | High Beam Assist |Voice Control | USB Audio | 8Jx17 | Storage | Through Load
06-10-2007, 09:58 AM | #2 |
213
Rep 3,835
Drives: Jerez E90 M3
Thats a Pearl? Than it works fine.
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 | |
06-10-2007, 10:06 AM | #3 |
Freude am Fahren
336
Rep 5,254
You're in the U.S. He is in the U.K.
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
06-10-2007, 10:10 AM | #5 |
310
Rep 15,745
yeah I was about to say. Mine works fine as well. Got no issues with it.
Try deleting the connection from the phone and having the car search again for a pairable device? Mine didn't pick up after T once....reset the phone and deleted the contact from the car. After that it worked fine. The 8100 is not a BMW approved phone (not on the site in the US at least), so it works, but if any problems they won't fix it for you under warranty. If you are still having issues, the TCU can always be disconnected, then plugged back in (with the key out of the car)...sometimes it needs a reset to get it working again..much like computers. However Im not sure where the TCU is in the E93...most likely in the trunk somewhere..but I haven't had the chance to work on one. |
06-10-2007, 10:13 AM | #6 | |
Freude am Fahren
336
Rep 5,254
Since U.S. and U.K. systems aren't comparable, all I can say is that in the U.S. the Pearl has tested fine with several hundred phone numbers total and has worked flawlessly. Of course, with different TCUs, YMMV.
Freude am Fahren.
06-10-2007, 12:29 PM | #7 |
Rep 29
Hi all, and thanks for you inout.
No i have about 200 phone numbers in total (that includes those with multiple numbers. I'll try deleteing the phone from the car and then re-pairing and see what happens. I'll let you know - its good to know that others do have it working though Thanks again Alex
06-10-2007, 12:37 PM | #8 | |
Freude am Fahren
336
Rep 5,254
200 phone numbers in total is definitely not too many but if the phone is not compatible in your market, that may reflect a different problem.
Freude am Fahren.
06-10-2007, 02:25 PM | #10 |
Rep 29
Hi Jonathan
yes I appreciate that the other posters are in the US, but presumably, the software in my 8100 is the same, so the difference is presumably in the car's software, but would have thought that the bluetooth bit would be fairly standard. Anyway, unpaired, removed, and re-paired but no joy, gets to the letter E and then stops. In the UK, the bluetooth list shows the 8100 as only having limited functionality. Is that not the same in the US? I do appeciate BMW's problem - phones chane every 10 months or so, and its seems that the bluetooth used is not always standard, so it must be a nightm are for them, but still a bummer. Cheers anyway Alex
06-10-2007, 02:33 PM | #11 |
Freude am Fahren
336
Rep 5,254
The phone is presumably the same (although that is not a guarantee because each mobile operator has a tendency to insert their own software which can modify functionality incl. Bluetooth functionality) but the TCUs are worlds apart.
BMW doesn't even have the Pearl/8100 on their list but their list is very limited and out of date. I have tested about 25 mobiles (report is to be published online within 2 weeks I am told) and the Pearl did do really well in the tests. This was of course with BMW NA TCUs.
Freude am Fahren.
06-10-2007, 02:56 PM | #12 | |
148
Rep 5,389
|2009 RENNtech MB C63 AMG | Black/Black Leather/Black Maple | Premium II | MultiMedia | iPod | | TeleAid | Charcoal Filter Delete | BMC High-Flow Air Filters | High-Flow Secondary Cats | Clear Side Markers | |
06-10-2007, 03:02 PM | #13 |
Rep 29
Sounds as if the OS in the 8830 is better than 8100, I dont even have the ability to categorise my contacts - chance would be a fine thing:
Alex
06-11-2007, 01:14 PM | #14 |
39
Rep 330
The addresses must be saved to the phone's memory to work. Addresses on the SIM card will not be displayed. Perhaps this is the problem? Just a thought.
- Ian |
06-11-2007, 01:38 PM | #15 |
Rep 29
Hi All - thanks for all your suggestions - established what the issue was. For others who might have yhe same problem - on the 8100 I had set up a group called 'Family'. The address book transfer was bombing out at the letter 'E'.
Family was the first entry on the 8100 in the letter 'F'. Deleted that and all of the address book transferred without a hitch. My fault for not checking the 8100 rather than looking for problems on my computer. So the moral is - get rid of any groups on the 8100 Than ks again all for your suggestions - its nice to know that there is abunch of people happy to offer help to others Alex
06-11-2007, 02:01 PM | #16 | |
Freude am Fahren
336
Rep 5,254
Freude am Fahren.
07-30-2007, 08:05 PM | #17 |
World's Foremost Authority
1181
Rep 4,535
Drives: M4 Cab - Cayenne GTS - Jag XK
Location: Upper East Side Manhattan - Boca Raton FL - Lime Rock CT
I had the same experience. The address book will synch until it get to a group. Deleted the group and it synced up perfectly.
