Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > How to get the new Idrive software?
      06-08-2007, 09:25 PM   #1
jacksonjw81
Drives: 335I
How are you guys doing it? My dealer says they just will not upgrade it, so what are you telling them, so they update it?
Thanks
      06-08-2007, 09:30 PM   #2
continentalg5
continentalg5's Avatar
Drives: BMW
Tell them that you're iDrive goes too slowly or that your arrow display goes away during navigation. I don't remember what exactly it was but there is a service bulletin stating the exact reason for the upgrade. They must do it, if not I would go to another dealership.
      06-08-2007, 11:15 PM   #3
CASHBY
Drives: E90 335 "done up"
+1 one...that is what we did with my car and the M5..andt he updated it.
      06-09-2007, 11:11 AM   #4
jacksonjw81
Drives: 335I
Thanks, I searched for the TSB but couldn't find any.
      06-09-2007, 04:13 PM   #5
bartman32
bartman32's Avatar
Drives: F87 M2
2017 M2  [0.00]
Here you go You can read up more on this thread...
http://www.e90post.com/forums/showth...t=54505&page=9
SI B 61 03 05
General Electrical Systems April 2007
Technical Service
This Service Information bulletin supersedes S.I. B61 03 05 dated March 2007.
designates changes to this revision
SUBJECT
Software Errors Corrected with Progman
MODEL
E90, E91, E92, E93 (3 Series)
Vehicles produced up to March 30, 2007
SITUATION
Customer may complain of the following:
The following software errors were corrected with the release of Progman 25.01.00 (Target data Status E89x-07-03-520). Only software errors that are corrected with the last 2 Progman versions will be listed.
CCC (Car Communication Computer) equipped vehicle, the SDARS (Satellite Radio) stored station list is intermittently empty since programming with Progman V25.00.00.
Poor RTTI (Real Time Traffic Information) reception. The CID (Central Information Display) is constantly displaying "Transferring Messages" since programming with Progman V25.00.00.
After vehicle programming PDC (Park Distance Control) FC 9e28 is stored. Carry out a power cycle (ignition Off/On) and clear the fault memory.
The following software errors were corrected with the release of Progman 25.00.00 (Target data Status E89x-07-03-515).
If there is an incoming telephone call while SVS (Voice Input System) is active it is not possible to accept or reject the call.
A loud humming noise can be heard from the auxiliary fan when the vehicle is idling.
The automatic transmission enters "Failsafe" mode during a 5-4 downshift. EGS fault "AF8D – ratio monitoring 5-4 gearshift plausibility" is stored.
CCC: The programmable diamond MFL button does not work when set to "Next entertainment source" when vehicle is in motion.
CCC: The customer occasionally has poor radio reception after the vehicle was programmed with Progman V23.x or V24.x.
The speedometer and tachometer needles shake when the vehicle is idling.
CCC: Slow response to inputs made when using controller after startup.
CCC: A high frequency whistling noise intermittently can been heard in radio mode
CCC: Navigation system pop-up arrow display missing. Refer to SI B84 61 06.
CCC: CD/CDC track advances after key cycled. Refer to SI B65 32 05.
SDARS (Satellite radio) receiver fault "A537 – Sat aerial short circuit" is stored.
The following software errors were corrected with the release of Progman 24.00.00 (Target data Status E89x-06-12-510).
      06-09-2007, 05:31 PM   #6
jacksonjw81
Drives: 335I
SI B 61 03 05
Technical Service
SUBJECT
MODEL
SITUATION
Thanks a lot, I actually have a couple of those.
      06-09-2007, 06:42 PM   #7
1001
Drives: 06' 325i/08' 350z/09' 128i
my dealer did it for me without me even asking. now the background color is gray and not brown anymore.
      06-12-2007, 01:51 PM   #8
jrios_jr
First Bimmer
Drives: 3333555
if they still say no, tell your SA that you are going to call BMWNA and put a complain against them!! they HAVE TO DO IT! they might say we dont have that software tell them u will tell bmwna that the dealership is not up to date.
      06-12-2007, 02:29 PM   #9
bartman32
bartman32's Avatar
Drives: F87 M2
2017 M2  [0.00]
Has anyone heard of their DVD or CD just randomly spinning up? I got in my car the other day to get something. Key was not in my pocket but in the house and I heard the CD spinning up. Happens all the time on the road too. I think it is the DVD. Is this a "reason" to upgrade. My pop-up seems to work so I can't use that excuse.
Thanks
