2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Change runflat tires
      03-12-2012, 01:12 AM   #1
Artur-F10
Artur-F10's Avatar
43
Drives: BMW F12 M6
Hi
I want to change my runflat tires to non-runflat. I noticed that many of you did it. So, if you have some problems with your tires, how are you going to fix it? Do you have a spare tire in the trunk?
front tires: 245/19. Rear: 275/19
      03-12-2012, 10:58 AM   #2
bimmer man
Norway
77
Drives: 745le xdrive 2020, i3 2020
2020 745le  [0.00]
2012 640i  [10.00]
You can buy mobillety kit at your local BMW dealer. includes air compressor 12v and the sealing material on the bottle.
      03-12-2012, 02:19 PM   #3
Artur-F10
Artur-F10's Avatar
43
Drives: BMW F12 M6
But sometimes it will not help, especially when travel for a long distance
I found this spare tire kit, but do not know if it fit with 19'
http://www.bimmerzone.com/BMW_Perfor...T-F10-KIT.html
      03-12-2012, 02:57 PM   #4
tp550i
tp550i's Avatar
Drives: 2011 550i Sport
I have the same spare "kit" as pieced together here with the Maxxis tire.
http://f10.5post.com/forums/showthre...ighlight=spare
From the looks of the Bimmerzone ad, it also includes a centering ring, so it may be the exact same setup. Cover it and strap it down.
I also keep a ContiComfortKit in the trunk as a back up. It fits nicely in the passenger side trunk compartment.
You can get those from TireRack
http://www.tirerack.com/accessories/detail.jsp?ID=38
F10 550i Space Gray | Dinan Stage 5 | Eisenmann Race | ACS springs | 20" Ferric Grey 312 - Michelin PSS
      03-12-2012, 03:03 PM   #5
Artur-F10
Artur-F10's Avatar
43
Drives: BMW F12 M6
Thank you. You really helped.
what size are your wheels? this spare tire is 18, but I have r19 wheels
Also, does this spare tire fit the rear also or just front ?
      03-12-2012, 03:18 PM   #6
bimmer man
Norway
77
2020 745le  [0.00]
2012 640i  [10.00]
Yes this will fit, 18 ", 19" or 20 "rolling circumference should be them same. I am running on runflat tires due. Security these provide the high speed German autobahn.
      03-12-2012, 04:15 PM   #7
tp550i
tp550i's Avatar
OE was the 19", but now running 20" wheels/tires. As mentioned, the diameter is about the same. I believe the spare in my E60 was 18" rim and that was equipped with 19" M-sport wheels from the factory.
The spare fits both front and rear, front fitment is critical due to large front calipers.
Remember, its just to get you home or to repair, no autobahn runs
      03-12-2012, 04:41 PM   #8
Artur-F10
Artur-F10's Avatar
43
Drives: BMW F12 M6
what if it happened on my way to las vegas? lol
Also, do you think it is true that f10's suspension and other systems were made to work only with runflat?
Does it wear fast?
      03-12-2012, 08:30 PM   #9
tp550i
tp550i's Avatar
BMW recommends not exceeding 50mph and no more than 100 miles on the space saver spares. I've exceed both with no problems.
I am sure BMW will claim the suspension is "tuned" for the RF's, but after 6k miles with the Conti DW's I am not going back - no unusual wear at all.
5post
