Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > N00b question...
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      05-16-2005, 03:36 PM   #1
roburado
roburado's Avatar
Drives: '03 Passat, '09 Cayman S
1991 318is  [0.00]
N00b question...
Say I get 19 or 20 inch wheels. Does the odometer need to be reprogrammed or something? I think I heard that somewhere. Don't know if it's true.
      05-16-2005, 04:26 PM   #2
Mark
Administrator
Mark's Avatar
6731
Drives: 1M
Nope, it definatly does not need to get reprogrammed.
The reason is that even though your buying bigger rims, you'll be getting smaller tires, so that the overall wheel+tire combo will be the same size as stock. As long as the overall size is the same, then the car doesnt notice a difference and the speedo will be on check.
You can actualy use the calculators on the top of the wheel and tire forum to see how much of a difference there will be in the speedo with your new tire setup. Use the boxes on the right to set in a new tire size
For example, I used 19" wheels with my E46 once, and I put on 235/35/19 tires on the wheels, with that setup, according to the calculator, there is only a 1.53% difference, and my speedometer will read 61mph (when im really going 60mph), not enough of a difference to really matter
      05-16-2005, 06:48 PM   #3
roburado
roburado's Avatar
1991 318is  [0.00]
Cool. thanks.
E30 1991 318is, Red on Black Leatherette
Family History: Two E21 320i, One E28 535is, One E34 535i, One E34 540i
