ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Track / Autocross / Dragstrip / Driving Techniques
  TireRack
      03-05-2012, 10:28 AM   #1
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
VANOS nightmare before trackday
A bit more than a week before my 3/3 trackday with NCRC, I found out I have broken hub tab in my VANOS when I was adjusting my valve clearance. Quickly ordered parts, and cryogenically treated hub; VANOS was done in the same day I received the tools and hub. But that wasn't the worst nightmare, the broken tab fell into the timing chain area when I popped the VANOS apart. Fun started with harbor tools engine support bar ($69), a big surgery was carried out involving removing/disconnecting of steering column, steering rack, sway bar, reinforcement plate, subframe, engine mounts, FCABs, and headlight auto leveler. Luckily I was able to put my car back into one piece @ 1am before the event. Slept <5 hours and drove all the way up to Thunderhill
only a few photos (hands were always dirty and didn't have any helper).
Finally, I was chasing Porsches at the track again but with soft brakes (didn't flush it because of VANOS issue)
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      03-05-2012, 03:43 PM   #2
Trev
Drives: Z4MC
You sir are the man..... I respect someone that delves in & get's it done.
      03-05-2012, 05:51 PM   #3
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
We have a special dediated thread to dropping items in the engine bay by the way! Haha. Glad u got it out. How many miles are on the car?
      03-05-2012, 05:57 PM   #4
runnerx
runnerx's Avatar
Thanks Trev...
I never came across that thread somehow.. my z4m is more of a dedicated track car with almost 30k on the odo. It has done 3 years of avid autox and about 11 trackdays (never really counted)...
2009 BMW X5 4.8i
      03-05-2012, 06:04 PM   #5
runnerx
runnerx's Avatar
Here is one of my cam bolts... looks like Z4M has inherited the same hub and bolt issue from E46 M3.
2009 BMW X5 4.8i
      03-06-2012, 07:43 PM   #6
chickdr
140
Drives: 2006 M Roadster
I am in awe you took that project on by yourself. Great job getting it together before the track day. It certainly seems you did the job correctly based on the video!
      03-06-2012, 07:44 PM   #7
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Holy crap, that's some serious wrenching!!
Looks like you have 3 of the old bolts and 3 new cam sprocket bolts in the pic above.
      03-07-2012, 10:38 AM   #8
runnerx
runnerx's Avatar
chickdr - yeah I was glad I got all done before the trackday.
bignosejim - My car came with the old bolts. I took the shot after I replaced 3 old ones.
2009 BMW X5 4.8i
      03-07-2012, 07:53 PM   #9
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I could've helped take pix Chun
Oh well...I was busy that weekend anyhow with work & studies
      03-07-2012, 07:57 PM   #10
Finnegan
Dog Listener
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Best thing is that even with all that in the week before the trackday, and up till all hours, he was still there bright and early Saturday morning! Looked pretty good from what I could see (in person, haven't seen the video yet, need to be home to do that).
      03-08-2012, 02:04 AM   #11
Beedub
United Kingdom
423
Drives: 2007 Z4 M roadster vt2-500
vanos has so many design issues :-( sigghhhhh it WILL fail at some point from what im seeing......
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      03-08-2012, 08:57 AM   #12
udme86m
UDM.E86.M
udme86m's Avatar
Drives: 2007 MCoupe
Wow - that is a serious DIY! Most Impressive
06 Cayenne S / 07 MCoupe / 01 330CI / 04 K1200GT
      03-08-2012, 11:34 AM   #13
pokeybritches
pokeybritches's Avatar
Drives: ESS/G-Power Z4M, VF Z4, 996tt
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
How could you tell that you had the broken tab? Were there any noises or driveability issues? Also, what is your build date?
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 996 Turbo
      03-08-2012, 11:54 AM   #14
gcochard
24
Drives: 2011.5 E90 M3
2011 BMW M3  [0.00]
From what I've heard, one broken tab doesn't give any symptoms.
      03-08-2012, 12:52 PM   #15
runnerx
runnerx's Avatar
Cliffhopper is right.. no symptoms until both tabs are broken, but usually that is when your timing chain breaks and eats into other parts of your engine. You can see the exhaust hub when you do valve adjustment (second photo), and you can rotate the engine to check on the tabs.
How can I skip trackdays... I am registered for 4/7 already will be running in the Open group with my near stock Z4M on street rubbers. The only mods I have are GC coilovers + cryogenically treated exhaust hub + newer cam bolts (if they count) certain that I will fly by those E46 M3s with broken tabs or loose bolts.
that is why i bought the special tools from Tischer. I track this car hard and I am planning to check cam bolts and exhaust hub every other year since I do my own valve adjustment.
2009 BMW X5 4.8i
      03-09-2012, 04:30 PM   #16
tekmoe
tekmoe's Avatar
55
Drives: ///M
Props to you, bro. Definitely outside the realms of a simple oil change. And some serious dedication too.
      03-09-2012, 07:32 PM   #17
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
the best part was that you were calm and confident enough to document the fiasco the night before your track event....you sir are the man!
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      03-10-2012, 02:24 PM   #18
VinnieAces
VinnieAces's Avatar
92
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
wow, and i thought i was the man for doing a header swap all alone haha,
great job, and awesome vid! got a couple sweet kills!
///M - Some Mods 'N Stuff
      03-14-2012, 10:21 PM   #19
sipman
Drives: 2007 Z4MC
Saw in your video what looks like a cell phone mounted on the monitor. If you're interested in a really great mount, check out the Bracketron Universal Hold It mini. I've been using it to hold mine for track data and it's fantastic. It's a male and female tapered dovetail pieces that fit together super nicely. It's hold is fantastic, and removal is really easy, plus they are super cheap!
      03-23-2012, 02:52 PM   #20
DanFromTucson
Drives: Z4 M Coupe
Which bolts are the new style? The Torx bolts?
      03-23-2012, 03:00 PM   #21
gcochard
24
2011 BMW M3  [0.00]
Yes, torx are the new style bolts.
      03-24-2012, 04:38 PM   #22
SHADOW4
SHADOW4's Avatar
Sweden
44
Drives: Tanzanite M4 2018
2010 E89 35i  [0.00]
What a guy!
zpost
