03-03-2012, 05:25 PM | #2 |
256
Rep 4,721
Yep. I used it.
You do know the F10's brake pads does not generate as much dust as the E60, E90, etc. In all, I would say 50% less . By using this wheel wax, it does appear it's doing the job as intended. The advantage is simply it's a bit easier to wash the dust off. btw, I usually applied 2 coats. Applied one coat and let it dry and applied another coat later. |
03-03-2012, 05:34 PM | #3 |
60
Rep 438
Drives: F10 535i MSport, F15 X5 MSport
Yes; considerably less dust for sure. Just wondered if it was really worth putting on. It's only like $12 so no biggie; more so just the time to put on and what the results were.
Thanks! |
03-03-2012, 05:37 PM | #4 |
256
Rep 4,721
the real advantage is NOT let the brake dust baked onto the wheel. I am sure you have seen what they will look like if not washed off on a regular basis.
"Yellowish & black tar stained" |
03-04-2012, 11:15 AM | #5 |
116
Rep 1,346
Drives: 2011 E92 335 M-Sport
it protects the paint on the wheels and makes them easier to clean. Does little to nothing about the dust getting onto the wheels.
03-05-2012, 01:02 AM | #6 | |
7
Rep 79
Although I find that my brakes will 'squeak' occasionally when the car comes to a slow stop... Maybe the pads are harder..... |
