Will this fit ?
02-29-2012, 04:09 PM | #3 |
27
Rep 289
Cambers are really necessary ?
There is user here that has them on ... http://www.e90post.com/forums/showthread.php?t=584932 |
02-29-2012, 04:13 PM | #4 |
EUROPROJEKTZ
187
Rep 7,958
Drives: backwards
IIRC, the LCI hub is pushed out a little more compared to pre-LCI.
LTMW|SPEEDELEMENT|EUROPROJEKTZ
#TeamStretchNPoke |
02-29-2012, 04:23 PM | #9 |
27
Rep 289
02-29-2012, 04:25 PM | #10 |
81
Rep 6,092
02-29-2012, 04:25 PM | #11 |
Secret Asian Man
80
Rep 1,723
you can pull it off, just run a smaller tire combo like 225/35/19 and 245/35/19 (or 255/35/19) and itll work.
your car will look better than the others out there with sunken wheels that arent optimally fit |
02-29-2012, 04:27 PM | #12 | |
27
Rep 289
It will work after pulling and rolling fenders and camber kit ? Or It will work out of the box with those tires .... I'm on H&R coilovers so I can adjust height .. |
02-29-2012, 05:10 PM | #13 |
Pro Hater
49
Rep 1,717
There is a car with them and people are telling you no, it won't work... e90post never ceases to amaze me LOL
He said "Running Federals 225/35 fronts and 265/30 rear. I should've gone with a 245 rear but all is good with a littler rolling XD" 225/35 and 245-255/30 rear, fender roll, and you'll be fine on E90 LCI
Username is now PSUSMU
02-29-2012, 05:13 PM | #14 | |
Secret Asian Man
80
Rep 1,723
try them out first and set your coilovers at a height you like, then see if itll rub. if it does, you can either roll the fenders or set your alignment more aggressively (or do both if necessary) |
02-29-2012, 05:14 PM | #15 | |
Secret Asian Man
80
Rep 1,723
02-29-2012, 05:33 PM | #17 | |
Secret Asian Man
80
Rep 1,723
a 235/35/19 front and 245/35/19 rear setup (25.5 & 25.8 inch tall tires) would ahve the heights very close, or a 225/40/19 and 255/35/19 (both 26 inch tall tires) |
02-29-2012, 05:46 PM | #21 | |
Pro Hater
49
Rep 1,717
225/255 would be fine.. I run 225/265 on E90 LCI xDrive. Mine are almost 1% difference and there are no issues.
02-29-2012, 05:49 PM | #22 | |
Pro Hater
49
Rep 1,717
Ok, here, do this:
19x9" et24 225/35 19x10" et24 255/30 This shows a comparison to the setup I run. You will be nearly exactly how mine is, and I do not rub. http://www.willtheyfit.com/index.php...&Submit=Submit Quote:
/thread
