hid kit questions?????
02-29-2012, 09:30 AM | #1 |
7
Rep 84
ok so i bought my oem xenon headlights. waiting for them too arrive, im gonna go with lux angel eyes. not the leds, but the ones for the pre-lci cause i have an 08 328i. im gonna need hids and bulbs soon and also wiring and such to make everything work. what hid should i get??? should i go oem ballasts and get 6000K bulbs or what??? im confused with getting an hid kit and the compatability of the bulb with the xenon headlight. i hear ds1 bulbs, are the way to go, but if i buy an hid kit, does it come with those bulbs or what?? any help is appreciated. thank you fellas.
03-02-2012, 08:53 PM | #5 |
13
Rep 221
Xenons use projectors. So you just bought the housings?
Did you buy adaptive or non-adaptive housings? Adaptive housings will need SMC II modules installed, programmed, then coded. Buy the OEM ballast. You can get used ones off eBay for $150 ish each. I have one for a pre-LCI E90 I'll sell for $80 shipped. It has a dent in it but works fine. Search the lighting and vendor section for bulbs. I believe the oem bulbs are Philips. But Jeff should chime in with the bulbs. Not sure which ones works and which ones don't. Some cause problems with the oem ballasts. |
03-02-2012, 09:11 PM | #6 |
7
Rep 84
I bought the entire headlights. I have the ugly halogens right now. And they are adaptive. I definetely wanted the oem ballast and just wanted to change the bulb to 6000k. But want to make sure i buy the right stuff
03-03-2012, 11:26 AM | #7 |
3441
Rep 79,211
Ok well what bulb is currently in their. On the back of the halogen it will have the type.
