2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes H&R on 528 i M-sport
      02-29-2012, 01:36 AM   #1
commaps188
Drives: 335i
Hi
Does anyone have H&R springs on their 2012 528i M-Sport?
I would like to see some pictures if its ok
I plan on getting the 3D design lip , want to see how low it is or should I go with Eibach
TIA
      02-29-2012, 01:56 AM   #2
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
Check out my garage photos here:
http://f10.5post.com/forums/bpgarage...o=view&id=6081
I was lowered with H&R sport springs with those photos. Now I am with KWV3.
2011 F10 528i Black Sapphire / Oyster Black
2000 E46 325ci Cabrio Titanium Silver / Black - retired
1997 E36/7 Z3 Montreal Blue / Black - retired
      02-29-2012, 02:05 PM   #3
///M.Tonee
///M.Tonee's Avatar
Drives: Porsche 991.1 GT3
I heard you have to reset the chip or program something after putting on the springs on the msport...is this true? Also how do you adjust the headlight after the install?
Garage: 2015 991.1 GT3 | 2016 AMG GTS Sold | 2015 C7 Z06 Sold | 2015 M4 SO/6MT Sold
Instagram: M.Tonee
      02-29-2012, 02:33 PM   #4
commaps188
Drives: 335i
I want to go with KW's also but I don't want to loose the dynamic suspension thing
Did you loose yours?
TIA
      02-29-2012, 08:11 PM   #5
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
TIA
Do you have DHP (Dynamic Handling Package)? This is the electronic damper. Don't mix up with DDC. You can tell if you don't have the comfort function in your control. (comfort, normal, sport, sport+) vs. (normal, sport, sport+).
I don't have DDC so swapping coilovers has no affect.
      02-29-2012, 08:14 PM   #6
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
I did not re-program anything actually is not necessary. My msport kit is retrofitted. I had the standard F10.
Did not bother to adjust the headlight either. Drop is minor and will not affect headlight big time.
      03-01-2012, 11:19 AM   #7
commaps188
Drives: 335i
I can control it from comfort to sport +, so I guess the H&R is the only choice for right now then?
Was the H&R low enough?
      03-01-2012, 12:32 PM   #8
///M.Tonee
///M.Tonee's Avatar
I have these selections (Eco, comfort+, comfort, sport, and sport+). So I went with h&r for now.
Instagram: M.Tonee
      03-01-2012, 02:07 PM   #9
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
TIA
KW has the EDC delete option. If you set your suspension correctly, you should be happy with that setting. Changing the damping setting on the V2 and V3 isn't difficult.
Lowering your car on stock struts will eventually wear out those nice EDC struts. If they're blown, they're not cheap to replace especially when you need to trade your car in.
      03-01-2012, 07:49 PM   #10
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
Not sure if you guys have the electronic damper since you don't have the normal mode.
Check your suspension and see if they have wires, if so you have ED. See photos below:
      03-01-2012, 08:56 PM   #11
commaps188
Drives: 335i
Hi
I didn't KW has the EDC delete option? I was told its not out yet. Can someone confirm this I don't mind getting KW because I want to lower it pretty low
How does the EDC delete option do, will I be able to use the sport + modes
TIA
      03-01-2012, 09:33 PM   #12
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
Hi
TIA
It's out and another member here jaekeem has it.
Basically the EDC delete fixed the false signal and you will loose your electronic damper function. The DDC's throttle and steering adjustments remained.
      03-02-2012, 08:12 PM   #13
commaps188
Drives: 335i
Thank you for the info awesome I think I am going with the KW
5post
