New Brake Rotors
02-24-2012, 02:51 PM | #2 |
164
Rep 2,556
Can't go wrong w/oem brake parts. Tischer has good prices too. Cheaper aftermarket rotors include zimmermann, centric, stoptech, etc. I wouldn't bother w/slotted or drilled. Search rotors in this forum
2007 E90 335i, TiAg, 6AT, ZPP, ZSP, ZCW, 6FL, HD
Quaife lsd, ETS fmic, GIAC s/w, Dinan intake/exhaust/oc, Koni/M3 susp, Apex Arc 8, Mich PSS |
02-25-2012, 01:43 PM | #3 |
14
Rep 124
Another vote here for the full OEM setup. I just did all four wheels from Tischer. I would also recommend upgrading to the Z4 rotors at the same time. It is only a +$60 upgrade for the fronts.
02-25-2012, 07:18 PM | #4 |
40
Rep 818
EBC Ultimax rotors (dash slotted), way better than OEM for about the same cost.
Silent, super quality, awesome stopping performance. I'm using them with Cool Carbon pads. Better than I expected, I did a bunch of research. http://ebcrotors.com/p-224-ebc-ultimax-rotors.aspx |
02-26-2012, 01:49 PM | #5 | |
201
Rep 1,714
Drives: 2011 335i
Can you please provide some more info and review the ebc brakes you have. I need to change all my rotors and pads. Just want to know a little more and if you are having problems with them. thanks |
02-27-2012, 09:44 PM | #6 | |
40
Rep 818
I had a bit of a steering vibration on freeways depending on the surface previously (with OEM rotors), and more so with the M3 front strut brace installed, that's gone now. Last edited by AlanAZ; 02-27-2012 at 09:50 PM.. |
02-27-2012, 10:04 PM | #7 | |
201
Rep 1,714
Drives: 2011 335i
02-27-2012, 10:25 PM | #8 |
Mad Linux Guru On The Loose
1121
Rep 5,397
Drives: 2008 335i Sedan, 2023 M3
Purchase the Z4 35is rotors! They are two piece and are direct swap for the 335i
02-27-2012, 10:32 PM | #9 |
Rep 165
02-28-2012, 12:04 AM | #10 | |
9
Rep 338
That is my plan when the time comes. |
02-28-2012, 07:08 AM | #11 |
1121
Rep 5,397
The 335i rotors are 1 piece. The Z4is rotors are 2-piece and I believe about 3 lbs lighter. Dimensionally, they are the same! So they make a good cheap upgrade for us.
