06-01-2007, 01:57 PM | #1 |
34
Rep 171
Brake info from UK M3 sales brochure
Managed to get a sales brochure last weekend and reading through info it details the following information under safety and control and wanted to know if this is new for E92 M3 or not. Word for word from brochure:
"Dynamic Stability Control Plus(DSC+) comprising: Anti-lock braking system (ABS), Automatic Stability Control (ASC), brake drying, brake fade compensation, brake pre-tensioning, cornering brake control (CBC), dynamic traction control (DTC), electronic brake force distribution (EBD), engine drag torque control (MSR), hill start assistant, soft stop" Any of this on the E46? |
06-01-2007, 02:20 PM | #2 |
532
Rep 5,498
My E36 has ABS and ASC. EBD sounds new and similar to equipment available to Porsche owners.
Jason
Instagram: jellismotorwerks |
06-01-2007, 04:27 PM | #3 | |
Rep 55
Soft stop can't be any good..... I like to stop my own car. |
06-01-2007, 10:56 PM | #4 |
Commander-In-Chief
2115
Rep 8,918
E46 also has CBC. Brake drying, hill start assistant, soft stop & MSR are new, I believe. Agree on soft stop, whatever that is. I think I can modulate my stops just fine so my passengers' heads don't bob.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 Last edited by GregW / Oregon; 06-02-2007 at 10:47 AM.. |
06-02-2007, 01:37 AM | #6 |
374
Rep 8,033
Does someone have the exact technical specs on this soft stop thing? I can guess what it is trying to accomplish, but I want to know exactly how it is implimented. If it is what I am thinking, it sounds horrible.
06-02-2007, 02:55 AM | #7 | |
1312
Rep 10,185
It works great Some just need to get used to it As you are about to stop, it slightly releaves the pressure on the rear brake pads and stops the car more gently. Its designed to take 50% of the modulation needed away ( so if you dont modulate slightly, peoples heads wil still "bob" slightly ) Most E9x have it, and most E6x
BMW if you are reading, I need a job, Please. |
06-02-2007, 03:02 AM | #8 | |
35
Rep 563
Drives: 2007 E92 M3
While I will leave to my passengers to comment as whether I might benefit from the "soft-stop", I think it sounds a million miles away from the "Ultimate Driving Machine". More like technology for its own sake. |
06-02-2007, 03:22 AM | #9 |
1312
Rep 10,185
Its a standard feature on almost all BMW DSC systems since 2005.
It makes it a better drive for a huge amount of drivers that cant modulate properly
06-02-2007, 03:41 AM | #10 |
374
Rep 8,033
I don't mind the DSC. Actually, it might have saved my ass once. With regards to the soft stop thing: all I can say is that I hope there is way to turn it off on the M3.
06-02-2007, 10:40 AM | #12 | |
23
Rep 515
I will be a Master Tech for BMW when this car is out, so I'll figure a way to get it controlled or overridden. |
06-02-2007, 11:06 AM | #13 |
15
Rep 69
why in hell would they fit a break modulation system on a car that is suppost to be designed for proformance driving im talking about soft stop, i don't see the reasoning behind this, we have gotten along fine for years without it, now i can understand it on the normal 3 series, but an ///M thats just dumb
does the M5 have this? |
06-04-2007, 10:52 AM | #14 |
792
Rep 2,234
People are getting their knickers in a twist about something which is hardly even noticeable. I have it in my E90. I didn't have it in my E46 M3. I never even notice it to be honest.
06-04-2007, 11:02 AM | #15 |
374
Rep 8,033
If it is not something that is noticed, than why the hell is there? The whole point of the system is to make a difference in how the car comes to a stop, and that should be noticable. So, I have to question your perception. Or, maybe it has to do with the way you drive--maybe you like soft stops to begin with...
06-04-2007, 11:42 AM | #16 | |
792
Rep 2,234
Maybe when something does it's job properly you don't notice it. How about a referee in a sports game? You only notice them when they make a mistake. Basically, if you don't try to modulate the brake when you come to a stop, then you will notice it. If you do, and just drive normally, then you don't need it to take over for you. |
06-04-2007, 12:04 PM | #18 | |
374
Rep 8,033
06-04-2007, 12:13 PM | #19 | |
792
Rep 2,234
However, you don't notice soft stop unless you drive in a particular way. So if you don't attempt to stop the car smoothly, then you will notice it. If you drive normally, and try to drive smoothly, then you will not notice soft stop because it won't need to intervene. However, the brake assist can be annoying. If you tap the breaks quickly but with little force, it can confuse the system and 'think' you want full force breaking, which can be jerky. |
06-04-2007, 01:14 PM | #20 |
374
Rep 8,033
I don't know what you mean by "normal" driving. Normal by what standard?...Well, maybe I've judged the road conditions, and for whatever reason I want to come to an abrupt stop. Then the dumbass technology kicks in, and I'll be cursing at the car. I'm fine with these kind of interventions when safety is an issue. But clearly, in this case, safety is not an issue. And then like you are saying, with any such system, there are always problems with recognizing events, and making false interventions, which is even more annoying. The previous poster seems to be complaining about the same thing.
Anyway, I'll have to drive the thing and then I can really let it loose on the idiot who came up with the idea. BMW engineers are great with engines, suspensions, and other core systems, and that's where they should focus their energy. Stuff like this sounds purely annoying and is somewhat typical of BMW's orientation with unnecessary technologies... |
06-04-2007, 02:24 PM | #21 | |
792
Rep 2,234
The road conditions are pretty irrelevent really. It is a minor aspect of the driving experience and therefore I go back to my original point that people are getting their knickers in a twist about something which isn't a big issue. Just to make it clear so you know what soft-stop is. When you apply the foot brake to come to a stop, in a normal car unless you ease off very slightly on the brake, the car will come to a jerky stop. Soft-stop allows you to apply the same constant brake pressure, and for the very last fraction of a second it will release the brakes allowing you to come to a smooth stop. It is hardly noticeable. The road conditions are irrelevent. You can still come to an abrupt stop in the same way as you would without 'soft-stop'. I find it bizarre that you are complaining about something which you haven't even experienced yet! I tell you. You could drive it and you wouldn't even know it was there. |
06-04-2007, 02:35 PM | #22 |
Rep 23
They will have it for a reason they dont make extra costs when they could have left it out they are a company like any other trying to make as much profit as possible. I drive a 6 series often and you can easy do abrupt stops. and tested alto of BMW lately and never noticed anything trying to make it stop sofetly. just forget about you will not notice it anyways.
