      02-04-2012, 12:13 PM   #1
nicoz
10
Drives: 1M
N55 midpipes vs aftermarket?
What and why? Thoughts?
Thank you
      02-04-2012, 03:20 PM   #2
Papethova
224
Drives: '08 135/ '11 1M
Working on a total straight pipe now, similar to the Borlas (no cats no resonator) I had on the 135. Only difference I may up it from 2.25 to 2.5 in diameter.
Should be ready on Tuesday or Wednesday... in the meantime I am driving with NO mid pipes LOL
      02-04-2012, 06:15 PM   #3
Franklin Joseph
57
Drives: BMW
N55 will be the cheapest route (without hacking the stock midpipe)
I have the berk midpipe...gives a nice rumble, not too loud.
Curious to see what your straight pipe sounds like Papethova...is it gonna be bolt on (with the stock type flange) or a slip on?
      02-05-2012, 01:03 AM   #4
Papethova
224
Bolt on to replace the OEM perfectly and easily. I am having a jig made so I can replicate it for anyone who would like one.
My Borlas on the 135 were straight pipes, very similar to these, and I loved the sound and power gains. They however wont bolt right in and up to the stock muffler... or in my case potentially an Akra slip on.
      02-05-2012, 01:07 AM   #5
cooler2442
476
Drives: 1/18 Monte Carlo Blue E92 M3
Aftermarket mid pipes will sound better than the N55 one. I have a Berk full straight pipe with midpipes while my friend has just the berk straight pipe exhaust and N55 midpipe. His car sounds like a trucker while mine sounds much deeper / more aggressive. This is on an N55 engine but it still shows an example of what different mid pipes do.
      02-05-2012, 10:04 AM   #6
MDORPHN
290
Drives: AW 1M
Can't comment on the aftermarket pieces, but I'm running the N55 midpipe. Deeper exhaust note with occasional "burble" and drone almost altogether eliminated.
Neil
      02-05-2012, 10:29 AM   #7
Papethova
224
Anyone know how much the material matters? Is sound going to be different with aluminized vs stainless vs Ti?
Im also thinking about going to 2.5s instead of 2.25s anyone with experience on that (as far power gains or losses)?
      02-05-2012, 11:38 AM   #8
Franklin Joseph
57
Drives: BMW
materials = cost...depends on what price point you want to be in.
any thoughts of going with a Y from downpipe to a single pipe? maybe oval pipe? (assuming it will lower the weight)
      02-05-2012, 10:04 PM   #9
Papethova
224
precisely why I was asking.... I dont want to spend extra $$ on this project to just save a few pounds because I think an Akra is in the immediate future for me. However if it will impact the sound I will consider it.
As far as the Y near the DPs... well to get the volume (3 dimensional space not decibals) of two 2.5 diameter pipes I would need a single 3.75 inch pipe. I dont know how easily that will fit in the space. I dont want to stray from the round piping because I dont know how that affects turbulence and flow. If you or anyone has expertise in the area and can show me the benefits of it I will consider it.
There is significant weight saved between the OEM mid pipe and these, but yes there are a few pounds that can still be saved by going with a different material (Ti) or single larger pipe. I just dont know if the $$ or trouble is worth it for those last few pounds, especially as I said an Akra is most likely right around the corner.
      02-05-2012, 10:28 PM   #10
nicoz
10
Drives: 1M
Let me know about these when they're done.
Still can't decide between N55 midpipes (cheapest), aftermarket (best sound I guess)... and now your straight midpipes.
BTW do midpipes with or without res throw CEL?
Thanks again for your help guys
      02-05-2012, 10:33 PM   #11
Papethova
224
I should have something by weeks end.
They will not throw a CEL. Just remove 4 nuts and 3 bolts, swap the gasket to the straights and re-tighten the 4 nuts and 3 bolts. You do need to remove 6 bolts to remove a brace too.
If they sound anything like the borla straights did on my 135 I will be beyond happy. The Borla doesnt swap out with the OEM because it doesnt Y at the end. Closest ones available would be what meisterschaft has.
      02-05-2012, 10:33 PM   #12
Franklin Joseph
57
Drives: BMW
No CEL with midpipes. Both sets of O2 sensors are on the downpipe.
      02-06-2012, 07:27 PM   #13
nicoz
10
Drives: 1M
Ok thanks.
Keep us posted!
      02-07-2012, 03:16 AM   #14
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
i better be the first one you call after youve got them installed
      02-07-2012, 10:24 AM   #15
Papethova
224
You might have to wait a little longer. Im confused about something...
My calculations show the volume for two 2.25s to equal one 3.375. Trying to determine why someone would make a dual 2.5 since the bottle neck for the 2.25s was and is the 3 inch pipe connecting the Y to the muffler.
      02-07-2012, 10:42 AM   #16
Fundahl
Drives: VO 1M, 300zx TT
What do you guys think about resonated vs non-resonated? I'm not too concerned about drone, I have some unmuffled catless vehicles.
I just want whatever sounds most "mean" or "raw". Not "farty" or "buzzy".
      02-07-2012, 10:28 PM   #17
nicoz
10
Drives: 1M
Should be around 3.25...
      02-09-2012, 04:45 PM   #18
nicoz
10
Drives: 1M
Originally Posted by ianf View Post
I have MadDad mids which will be fitting in a few weeks
Where did you buy those... and how much.. if you don't mind!?
Thanks
      02-11-2012, 08:44 AM   #19
nicoz
10
Drives: 1M
Any news?
      02-11-2012, 01:35 PM   #20
Papethova
224
Any news?
It became cost prohibitive. Also, I couldnt decide what really needed to be done... 2.25s vs 2.5s, totally straight with no cats or resonator vs resonator like the maddad or N55 pipes.
I am looking at different options now, if anything develops I will provide updates.
      05-05-2013, 10:47 AM   #21
katsooba
katsooba's Avatar
84
Drives: bmw 135i
Hi,
sorry for the bump, but i noticed your calcs are pretty good, but you forgot one important thing about the cross sections of the pipe, which is flow restriction.
2 2.25" or 2.5" pipes will have more restriction friction wise on the flow, than a 3" or a 3.25" single pipe.
2 2.5 pipes have almost 2 times the friction of the 3.25" single pipe.
more friction = more heat, we dont like it, even if its on our exhaust.
im doing a 3.25" single midpipe soon,
if thats going to be hanging too low on the car ill just do a 3" midpipe.
i have a N55 engine with CP-E 5" downpipe [it was a bargain]
135i N55 / KW V3 / MHD Flash / Tons of grip mods / CP-E charge pipe / CP-E 7" FMIC
Search this Thread:
Advanced Search
