02-02-2012, 02:30 PM | #1 |
Rep 45
Wheel ET sharing
Hi Eveyone
I am looking for a set of wheels for my F10. I wanted to see if anyone wnats to share there set up like ET and size I am looking to get 20 to 22 , but I am leaning more to 20's Thanks |
02-02-2012, 09:35 PM | #3 |
159
Rep 1,173
IMO It depends on how wide you want to go with your wheel widths and how lowered your car is.
If you are significantly lowered: For the F10 on the rears with a 10.5" width, et +40 is the most aggressive without rubbing , but right on the verge of rubbing. For the F10 on the fronts with a 9" width , et +25 is the most aggressive without rubbing, but right on the verge of rubbing. This is just from my experience, if anyone has run more aggressive than that without rubbing, please chime in. |
02-03-2012, 01:17 AM | #5 | |
Rep 45
Anyone else |
02-03-2012, 01:19 AM | #6 |
Rep 45
Thank you for the info, I am not sure which why to go yet. This set up is not that aggressive right? Will the wheels be tucked in?
02-03-2012, 11:13 AM | #7 | |
50
Rep 519
I am also going to lower with ACS springs.. Last edited by DentalBoy; 02-03-2012 at 11:16 AM.. Reason: Add mas info |
02-03-2012, 11:30 AM | #8 |
8
Rep 147
I'm running 20" Giovanna Martunis on my car; 8.5" ET32 up front; 10" ET35 in the rear.
The wheels go right to the edge of the fender of my car (stock M-Sport suspension). If I dropped it with H&Rs, they'd tuck in perfectly. No rubbing. Aggressive look, just the way I like it. |
02-06-2012, 12:47 AM | #10 |
Rep 4
am also trying to find set up size tires for 22". if anyone can help me that be great. i tried searching on google and on the forums. if it has been said multiple time i apologized.
so far i got 22x9 +33 245-30-22 // 22x10.5 +35 295-25-22 thanks! |
02-07-2012, 02:40 AM | #11 |
126
Rep 1,583
Forged1- 7 Mesh Deep Concave
245/35/20 et22 Front 275/30/20 et35 Rear
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread: http://www.6post.com/forums/showthread.php?t=794659 |
03-09-2012, 04:08 AM | #13 |
171
Rep 657
F07
Front 20" x 8.5", 255 35 20 ET 15. Pretty much as wide as you can go. Rear 20" x 10", 285 30 20 ET 30, but I reckon I could squeeze in ET 25. I will fit 5mm spacers to the rear and find out.
540i
GTR-R35, F90 M5, X3MC, RS3, RS7, M5, S7, S3, RS3, RS6, GTR R35, 996 Turbo, M5, RS6 V10, Cayenne Turbo S |
