TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > help
      01-31-2012, 09:03 PM   #1
E39Rody
Drives: 2000 E39 528i m sport
help
Hi to all of you guys!! How do you guys doing?? I'm here posting this because I need your help I just brought a 2006 325i about 2 weeks ago it is close to the 100k miles!!! And I noticed a little vibrations at the engine when it's parked when the engine it's cold I noticed more the vibrations !!! So if any of you know what it should be! Please let me know I need your help!!! Oo and pics coming soon with some mods thank you guys
      01-31-2012, 10:42 PM   #2
Chriztofor
Chriztofor's Avatar
Drives: '06 325i and '13 X5
Ok, first start off by dumping a bottle of chevron techron fuel injector cleaner in the tank. If that doesn't work after 3 days then change your plugs and air filter. OEM plugs can be had at o'reillys for $40 http://www.e90post.com/forums/showthread.php?t=543384
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
      01-31-2012, 10:49 PM   #3
mike3000fl
138
Drives: 06 330i
only thing i would add to the above is clean the MAF if you do the air filter. its delicate and needs a special aerosol cleaner. read up on this if you have never done it. replacing it is not cheap.
      01-31-2012, 10:54 PM   #4
Chriztofor
Chriztofor's Avatar
You are hard core when it comes to that. I cleaned mine once with a maf sensor spray, but, out of curiosity, when i looked up the price to see how much it would cost to replace it (over $200?) I try to stay away from that!
      01-31-2012, 11:02 PM   #5
queensfield
Drives: 2006 330i E90
Two more things I will add to the above list, if vibrations do not go away- (i) clean your vanos solenoids (there is a DIY for it), and (ii) Pull codes from the OBDII (if you know someone who has a BT or Peake cable, please use- this may pin point the problem exactly.
      01-31-2012, 11:09 PM   #6
yakev724
yakev724's Avatar
231
Drives: 15 S3
change plugs oil air filter
      01-31-2012, 11:10 PM   #7
Chriztofor
Chriztofor's Avatar
Since we are being extra helpful, here is the link http://www.e90post.com/forums/showth...=486201&page=3. I would do this if all else fails.
      01-31-2012, 11:42 PM   #8
Chriztofor
Chriztofor's Avatar
Speak of the devil, O'reillys is selling the spray for $6.50 http://images.oreillyauto.com/upload...3_WARMCOLD.pdf
