Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Shifting to Reverse with Steptronic
      01-31-2012, 11:47 AM   #1
project6
TOML Rescue
Drives: Prancing Horse
Greetings all,
First BMW in the family. 08 328i with auto transmission. Is it normal for the gear shift lever to be able to be pushed in to reverse without depressing the lock button on the lever? (Brakes applied...otherwise,it won't go into D or R )
On my other cars, you can shift from N to D without depressing the lock button, but you need it to go into reverse. I thought it was a safety mechanism to keep you from pushing the lever to reverse un-intentionally.
I also read the manual and it states that "a lock prevents you from inadvertently engaging selector lever positions R and P". I don't think this is the case with this car.
Do I need to bring it in?
      01-31-2012, 02:37 PM   #2
edirtaynine
81
Drives: e92
lock button?
      01-31-2012, 02:47 PM   #3
project6
TOML Rescue
Originally Posted by edirtaynine View Post
lock button?
The button on the front of the gear selector lever. I guess technically it is an "unlock button".
Do you know the answer or did you want to clarify the "lock button"?
      01-31-2012, 03:51 PM   #4
zzzbullseye
BMW Addict
zzzbullseye's Avatar
Drives: 2011 550i (F10)
You have to depress the button to go from P to R and vice versa, I didn't think to check R to N and vice versa, but I suspect you have to depress the button for those actions as well.
'11 Black Sapphire F10 550i l ZSP l Avant Garde 20" M310
      01-31-2012, 04:01 PM   #5
project6
TOML Rescue
That's the thing, I can go straight from D to N to R without depressing the button. I noticed it as I was backing up in to my garage. I was on D and I just pushed the lever forward and it went straight to R.
I have to depress the button going to any gear if on P. The reverse position is what baffles me. None of my other vehicles will ever go to R without depressing that button. Is this a BMW only feature?
Sorry for the ignorance. I just wanted to clarify.
      01-31-2012, 04:11 PM   #6
Bimmer335i07
BK Employee of the month! / Moderator
Bimmer335i07's Avatar
Drives: BMW 335i Sedan
2007 335i  [0.00]
It's controlled by the computer. You can be going 50mph and shift it from D to R and nothing will happen.
Sponsored by: Pics of the ---> Barbera Beast <---
Martino Auto Concepts (Like them on Facebook MAC) Factory Trained & Authorized by BMW of North America
Matt@Camber-Toe (Like them on Facebook Camber-Toe)
LuxAngelEyes (Like them on Facebook LuxAngelEyes)
LTBMW (Like them on Facebook LTBMW)
OEMconcepts (Like them on Facebook OEMconcepts)
      01-31-2012, 04:25 PM   #7
zzzbullseye
BMW Addict
^^^ I suspect this is right. ^^^
For the record, this is the shift lever behavior while sitting at a stop with your foot on the brake:
P > R - requires button depressed
R > P - requires button depressed
R > N - does not require button depressed
N > R - requires button depressed
N > D - does not require button depressed
D > N - does not require button depressed
R > N > D does not require button depressed (note: this is while rolling in reverse slowly)
BTW...this is where someone from the manual transmission fanboi crowd chimes in with a snarky "autotragic" comment...
      01-31-2012, 04:39 PM   #8
edirtaynine
81
Drives: e92
ohhh that "button" lol.
      01-31-2012, 05:00 PM   #9
project6
TOML Rescue
This happens.
THIS does not happen. I can go from N > R without depressing the button.
That's okay. Fanbois will be fanbois, hence the term "bois" or "boys". These forums will always have the insecure kids who likes to proclaim they have biggest e-cock on the planet
      01-31-2012, 05:39 PM   #10
zzzbullseye
BMW Addict
Hmm...I'd have the dealer take a look at it next time you're in for service. If you're still under warranty, any repair should be covered. In the interim, I don't think it's a big problem, just something to be mindful of.
      01-31-2012, 05:49 PM   #11
project6
TOML Rescue
Ok, thanks. The car only has 32K miles and still under warranty. I'll have them take a look at it. I just don't want to go to the service department and find out that it is normal behavior.
      02-01-2012, 06:18 AM   #12
zzzbullseye
BMW Addict
I don't think it's "normal", but I also don't think it's a big enough issue to make a special trip to the dealer, just add it to the list of items to check next time you're in for service.
