Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Does a deployed airbag cause any damage?
      01-30-2012, 08:49 PM   #1
Vroom vroom
12
Drives: Looking for a 335i
So i found this perfect coupe 335i.. Except its been in an accident that caused its airbag to deploy and had to be towed.. The steering wheel was also replaced probably because of the drivers head hitting it.. : . Anyways my question is does the steering wheel being replaced and the airbags being deployed cause any actual damage if they fixed the car? Would i be able to know if the car had been hit pretty bad now or not? Would i be able to get the price down to 25k? Here is the car...
http://www.autotrader.com/fyc/vdp.jsp?ct=u&car_id=314595081&dealer_id=64590281&c ar_year=2008&systime=&doors=&model=335I&search_lan g=en&start_year=2008&body_style=COUPE&keywordsfyc= &keywordsrep=&highlightFirstMakeModel=&search_type =both&distance=75&min_price=1&rdm=1327977642455&dr ive=&marketZipError=false&advanced=y&fuel=&keyword s_display=&sownerid=51167445&lastBeginningStartYea r=1981&end_year=2013&showZipError=n&make2=&certifi ed=&engine=&dma=MIAMI-FT_LAUDERDALE_FL&page_location=findacar%3A%3Aispse archform&body_code=2&isFlashPlugin=false&transmiss ion=&default_sort=&max_mileage=45000&color=&addres s=33060&sort_type=priceDESC&max_price=26888&make=B MW&seller_type=b&num_records=25&cardist=34&standar d=false
      01-30-2012, 08:52 PM   #2
crzylildude
crzylildude's Avatar
Drives: 2007 335i Coupe
If airbag deployed meaning structural damage... so don't not even for 25K .... NOOOO!
      01-30-2012, 09:04 PM   #3
Vroom vroom
12
Does it always mean structural damage?
      01-30-2012, 11:34 PM   #4
crzylildude
If it did not hit any structure the airbag wont deploy... and they want 25K... I say 15K that's all you should offer them... walk away there is alot other out there... If you can sense that there is something not right... then it means that it is not right...
      01-31-2012, 12:13 AM   #5
JBE90335
27
Drives: 2007 E90 335i
that's such a bad deal. I've seen CPO'd coupes on BMW lots for that price.
      01-31-2012, 12:14 AM   #6
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
Airbag deployment is based on detected rate of deceleration.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      01-31-2012, 04:31 AM   #7
Chriztofor
Chriztofor's Avatar
Drives: '06 325i and '13 X5
http://www.autotrader.com/fyc/vdp.jsp?ct=u&car_id=314595081&dealer_id=64 590281&car_year=2008&systime=&doors=&a mp;model=335I&search_lang=en&start_year=20 08&body_style=COUPE&keywordsfyc=&keywo rdsrep=&highlightFirstMakeModel=&search_ty pe=both&distance=75&min_price=1&rdm=13 27977642455&drive=&marketZipError=false&am p;advanced=y&fuel=&keywords_display=&s ownerid=51167445&lastBeginningStartYear=1981&a mp;end_year=2013&showZipError=n&make2=&amp ;certified=&engine=&dma=MIAMI-FT_LAUDERDALE_FL&page_location=findacar%3A%3Ai spsearchform&body_code=2&isFlashPlugin=fal se&transmission=&default_sort=&max_mil eage=45000&color=&address=33060&sort_t ype=priceDESC&max_price=26888&make=BMW&amp ;seller_type=b&num_records=25&cardist=34&a mp;standard=false
I stopped reading after I read.....I found the perfect coupe except it has been in an accident.... lol
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
      01-31-2012, 08:15 AM   #8
Vroom vroom
12
http://www.autotrader.com/fyc/vdp.jsp?ct=u&car_id=314595081&deal er_id=64590281&car_year=2008&systi me=&doors=&model=335I&sear ch_lang=en&start_year=2008&body_st yle=COUPE&keywordsfyc=&keywordsrep =&highlightFirstMakeModel=&search_ type=both&distance=75&min_price=1& amp;amp;rdm=1327977642455&drive=&m arketZipError=false&advanced=y&fue l=&keywords_display=&sownerid=5116 7445&lastBeginningStartYear=1981&e nd_year=2013&showZipError=n&make2= &certified=&engine=&dma=MI AMI-FT_LAUDERDALE_FL&page_location=findacar%3A %3Aispsearchform&body_code=2&isFla shPlugin=false&transmission=&defau lt_sort=&max_mileage=45000&color=& amp;amp;address=33060&sort_type=priceDESC& amp;amp;max_price=26888&make=BMW&s eller_type=b&num_records=25&cardis t=34&standard=false
Thanks for being so helpful funny guy.
      01-31-2012, 08:17 AM   #9
J3NGOe90
Drives: e92 335i 6speed MT only!
bad dealll
      01-31-2012, 08:22 AM   #10
ceb
NHTSA Nazi
28
Drives: 335ix
Incorrect. There are literally millions of calculations that go into a modern airbag deployment but the bottom line question is always "will the deployment reduce or limit the severity of injury?" If it will, then the airbag will deploy.
First gen airbag cars had hardwired sensors behind the bumpers - whack it hard enough and it'll go off, but all that is changed now.
      01-31-2012, 08:23 AM   #11
crzylildude
$25K????!!!! No way I don't care what they say or the others might think.... Walk away my friend... find a CPO... this is a NO-BRAINER
      01-31-2012, 08:36 AM   #12
ndog14
Drives: E90 328xi 6MT
Yup. And being a 335 the accident occured at a higher rate of speed, assuming.
      01-31-2012, 09:38 AM   #13
doubleIN
atlien
doubleIN's Avatar
15
Drives: '11 e90 335i
2011 BMW 335i  [8.50]
I would never buy a car if I knew the airbag had been deployed. there are so many cars out there, go find one that hasn't been wrecked! You think you're getting a good deal but any money you save up front on the purchase price you will end up shelling out in the end because there will be a lot of stuff that wasn't fixed properly and you'll have no idea until things start failing, breaking, and falling off
2011 e90 335i: AW/Oyster | M Sport | BMW Performance (Power Kit v1, Exhaust, Suspension, rear and side aero kit, 19" 313s)
      01-31-2012, 09:56 AM   #14
JuppiOne
25
Drives: everyone crazy
I don't know about the OP, but knowing my car was in a serious accident (in this case, air bag deployed) will definitely bug the holy shi# out of me, there are going to be tought on the back of my mind, what happened and what didn't get fixed or didn't get fixed right, and whats going to break soon .... to many concerns, thats going to drive me nuts
      01-31-2012, 10:04 AM   #15
crzylildude
"Would i be able to know if the car had been hit pretty bad now or not? Would i be able to get the price down to 25k? Here is the car..."
Hey guys i read what OP posted again... they are even asking for more than 25K???!!!! what the?!!
      01-31-2012, 10:16 AM   #16
JTILAK07
Drives: 09 E93 CR.
first off it does not mean that there is structural or frame damage just because the airbag deployed. it could of been a simple fender bender causing the airbag to deploy. Especially on these vehicles since there are two airbag crash sensors right behind the front fender by the headlights.
as for wanting 26k for it, its not that bad but i would say offer them 23-24k since it did have a deployed airbag. and even after the airbag has been deployed and then replaced this does not cause a weakened safety system in the vehicle. everything will still work as it should. I'm not trying to sell you or the vehicle but I am in the business and I'm just giving my point of view from a professional in the business.
***also if you really wanted to purhase a vehicle alot of dealers would let you take it to a repair facility or dealer to have it inspected before you buy it. I do that if my customers want. But it's at your(the customers) expense.
      01-31-2012, 10:21 AM   #17
CamelBiscuit
Drives: 11 E92 335i
2011 E92 335i  [10.00]
I wonder if you taped a football to the steering wheel would it come off with enough force to jack you up if the airbag deployed?
      01-31-2012, 10:38 AM   #18
doubleIN
atlien
doubleIN's Avatar
15
only one way to find out
      01-31-2012, 11:08 AM   #19
crzylildude
Dude! why would you advise OP to re-consider this shit, when there is a lot of cars in FLORIDA that is For Sale in this forum that is worth looking at than listening to whoever is selling him this car.... if you insist show him all the paper work from a CERTIFIED BMW COLLISION CENTER and CARFAX so OP will know the real facts about the HISTORY of the car.... then only then he will feel satisfied and at ease if he wants to make a deal with this dream car he is looking at...I still say walk away and get a CPO car there is a lot out there... Also he is not even at a BMW Dealer he is at an AUCTION CENTER
      01-31-2012, 11:15 AM   #20
edirtaynine
81
Drives: e92
wat makes it the "perfect coupe 335i" to u?
      01-31-2012, 11:56 AM   #21
JTILAK07
Drives: 09 E93 CR.
I'm just stating the facts man. LIKE I TOLD HIM AND I'LL TELL YOU TOO: I AIN'T TRYING TO SELL THE CAR NOR AM I TRYING TO SELL HIM. people tend to become arrogant douche-bags when they hear an airbag or two was previously deployed and think that major damage was done and the car isn't safe anymore. I just stated that the vehicle DID NOT have to be hit hard to sustain frame or structural damage for the airbag to deploy. I just offered an opinion on what i think he should have paid IF he wanted the vehicle. and the vehicle was for sale on autotrader.com listed by a DEALER(NOT BMW DEALERSHIP). ALSO I stated that and I quote myself: "***also if you really wanted to purhase a vehicle alot of dealers would let you take it to a repair facility or dealer to have it inspected before you buy it. I do that if my customers want. But it's at your(the customers) expense."......In the quote there I never said anything pertaining to this specific vehicle he wanted to buy. I stated that ALOT OF DEALERS(wheter private or not) WOULD LET YOU take the vehicle for a PRE-SALE INSPECTION. The choice of where is upto you hence I said REPAIR FACILITY OR DEALER(meaning BMW dealership) and its at the customers(in this case if he wanted to get it done to know info on the car, HIM)....So don't try to bash me man.
      01-31-2012, 12:01 PM   #22
N54B30A
N54B30A's Avatar
Lebanon
224
Drives: 2021 HS M2C
Airbag doesn't always mean structural it can just mean that there was a pretty big change in velocity in a short span of time.
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD
