Flat tire..
01-30-2012, 07:23 AM | #1 |
Rep 51
Drives: 2014 f30 335 xdrive, m sport,
Flat tire..
I was driving home Saturday night and hit a pot hole. Immediately got all the TPMS warnings (FYI, I don't have run flats). Pulled over and had low pressure, but enough to get back home. The next morning I went to give it some air to see if I could get it down to discount tire, but I couldn't get it to hold pressure.
Do you think it's just the tire, or the wheel to?
Current: 2014 F30 335i xdrive msport
2013-2017: 2011 335i e90 msport 2009-2013: 2008 328xi E92 |
01-30-2012, 07:49 AM | #2 | |
AC
95
Rep 2,387
given you hit a pothole, it could very well have blown the tire and bent the rims. you have to ask the tire shop to take the tire out for inspection.
Your Supreme Leader
01-30-2012, 07:50 AM | #3 |
37
Rep 222
01-30-2012, 08:01 AM | #4 |
BimmerPost Supporting Vendor
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
I'd say the rim was bent/cracked. Check for that. It has to have an outlet other than the tire being "gone." For it to not hold pressure, yes.
01-30-2012, 08:58 AM | #5 |
47
Rep 1,160
Youd have to check by taking the wheel off and exampling for bends or cracks
Monaco Blue 330xi - Terra Interior/6-MT/Sport/Premium/Cold/CSL's/M3 Spoiler Lip/Black Kidney's
01-30-2012, 11:11 AM | #6 |
Rep 25
My wife cracked a rim this past Saturday. She has no idea what she hit. Seriously. At least she didn't damage the tire. The guy at the tire shop said he sees at least one cracked rim per week. Just last week he had a lady in a Jag crack 3 rims at the same time (guess I shouldn't complain).
Apparently our rims are easily cracked, I hope that's not the case for you. |
01-30-2012, 12:10 PM | #7 |
819
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
It could be either. I've had both happen.
I've had pothole that just had a slight enough tear to not keep pressure, and on the other hand I had a pothole that didn't deflate the tire but bent the rim. Throw in some fixaflat and get it to your tire shop. |
01-30-2012, 05:55 PM | #8 |
Rep 51
Got the wheel off and took it in. It was just the tire. The sidewall in the back had a crack in it.
Getting the tire off was the biggest PIA ever. The wheel and hub were corroded together and I seriously spent half a hour trying to get it to budge.
01-30-2012, 06:35 PM | #9 |
45
Rep 1,754
01-30-2012, 06:49 PM | #10 |
Where'd my VTEC go?
481
Rep 6,067
Hubs, yes. Bolts, no. You don't want to lubricate the lug bolts because that can cause over-torquing and lead to snapped bolts.
