The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: Replacing Foglight Bulbs(aftermarket or OEM). 56k death.
      10-27-2005, 09:08 PM   #1
lux.sh
missing two turbos.
lux.sh's Avatar
Drives: fast around corners.
Before you do this:
1. Do it at your OWN risk.
2. MAKE SURE TO USE JACK-STANDS when you lift up your car.
I didn't use it this time because I already did this before and
it took me few minutes to complete. I did use extra support jacks
when I did it the first time.
3. DO NOT touch the bulb with your barehand. Hold the base, never the bulb itself.
4. You might need to do extra work if you have big hands.
Instruction:
1. Tools I used. 8mm socket, wrench, 2-ton jack, extra light support, aftermarket yellow foglight bulbs.
Oh yeah, and small hands required.
2. Lift your car. You don't have to lift it alot if you don't have big head.
3. Get under the car, Take off all the bolts that the red arrows are indicating.
Close-up pic of the 3 bolts you can't see.
One of the "bolt" in the middle is actually a clip. Pull out the middle piece with minus screw driver. real easy.
Close-up pic of the bolt you have to take off by the fender area.
4. Pull the air-splitter thingy off.
5. Pull the whole plastic panel off.
6. Now you'll see the foglight bulb in place.
7. Reach for it, and twist the bulb socket off the foglight housing.
8. Take the socket out, take the bulb out, replace it with new ones.
9. Place the bulbs you've taken out in a safe place if you plan on using them in the future.
10. Put the new bulb in. Put the bulb socket back in, the exact same way you took it out but reverse twist.
11. Reverse process, put everything back in, screw the bolts/clips back in. Enjoy the new bulbs.
For comparison between the Luminics JDM Yellow bulbs vs OEM bulbs,
please refer to this thread.
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty
: Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim :
: MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior :
      10-27-2005, 09:15 PM   #2
Mark
Administrator
Mark's Avatar
6731
Drives: 1M
great writeup ! thanks, i'm putting this is the ultimate compilation thread
      10-27-2005, 09:29 PM   #3
lux.sh
missing two turbos.
lux.sh's Avatar
Thanks mark.
      10-28-2005, 08:17 AM   #4
tiga901
tiga901's Avatar
7
Drives: e90 330i, mt pp sp
Great pictures...very informative!!!!
I bow to you!!!!!
      10-28-2005, 10:49 AM   #5
RedStripe
RedStripe's Avatar
Drives: 2006 BMW 325i
2006 BMW 325i  [0.00]
great post. Thanks very much
      10-28-2005, 12:55 PM   #6
chris
chris's Avatar
Drives: Jet Black e90 330i
nice! thanks for the wonderful DIY!
      10-31-2005, 09:28 AM   #7
thd13
thd13's Avatar
46
Drives: A07 330i
2006 330i  [0.00]
Great write-up!!! Now for the Angel eyes...
My other ride is your mom.
      10-31-2005, 10:08 AM   #8
afocoryw20
afocoryw20's Avatar
12
Drives: X3 + 325xi
2006 325XI  [0.00]
2005 X3  [0.00]
1990 Mercedes Benz ...  [0.00]
This is why this forum is the best!
      01-17-2006, 06:45 PM   #9
JNg1
Drives: E90
HIHI
Thaks your photo help me a lot. can u tell me what model is your FOG light
Many thanks!!
      01-19-2006, 12:30 AM   #10
lux.sh
missing two turbos.
lux.sh's Avatar
No problem.
What model is my foglight? I don't quite understand that question..
Its Luminics JDM Yellow bulbs for H11 application.
      01-24-2006, 05:52 PM   #11
JNg1
Drives: E90
Originally Posted by lux.sh
No problem.
hihi
I WANT ASK HID FOGLIGHT FOR E90 IS H7 OR H11???
THANKS YOUR HELP
      01-24-2006, 07:06 PM   #12
lux.sh
missing two turbos.
lux.sh's Avatar
JNg1, H11 works perfectly fine.
      01-26-2006, 10:40 PM   #13
HRC
MAUI BUILT
HRC's Avatar
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
Nice wright up Lux! I may end up replacing with some ION yellows again.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      01-26-2006, 10:42 PM   #14
lux.sh
missing two turbos.
lux.sh's Avatar
Danny
no problem danny!
Post some pics when you do. Ion Yellows look great from what i've seen so far.
      01-26-2006, 11:41 PM   #15
DILLIGAF
7
Drives: 2006 SG 330i ZSP MT CA
2006 330i  [0.00]
Looks good...thanks for the DYI pics
2006 330i
Sparkling Graphite/Sport pkg/Comfort Access/Aluminum Pedals/35% LLumar tint/Blacklines/OEM Shortshift knob
      01-28-2006, 01:04 PM   #16
poldim
Vroom Vrrooooom
poldim's Avatar
Russian Federation
300
Drives: 330i
2006 330i Sedan  [0.00]
2003 GSX-R 600  [0.00]
Nice how to....
while crawling around in that fog light space, did you see any open spaces where an HID ballast could be mounted next to the bulb?
-Dmitriy
06' BMW 330i & 03' Suzuki GSX-R600
SG | Beige Dakota | Poplar || iDrive w/MP3 | PP | SP | CWP | PDC | Comfort | Shades || 40% Tint
| Black Line Tail Lights | Hardwired V1
      01-28-2006, 03:36 PM   #17
lux.sh
missing two turbos.
lux.sh's Avatar
Originally Posted by poldim
Nice how to....
Thanks poldim. You know, if you look at the 2nd pic from the bottom, there is a huge space in there. I should've looked more carefully to see more about angel eye/HID connection. I totally forgot about it. Perhaps maybe someone can post a pic of the inside when they do this DIY?
      01-28-2006, 04:46 PM   #18
poldim
Vroom Vrrooooom
poldim's Avatar
Russian Federation
300
Drives: 330i
Im going to be ordering the chepo HID's for the fogs. I figure since its only 225 bucks shipped, if they break in a few years I wont care. But I need some place to mount them.
Its probably a 3x4x1 inch brick. Hopefully there is something I can either zip tie the thing to or screw it to some hidden plastic pieces.
-Dmitriy
      01-28-2006, 05:13 PM   #19
db17k
Chicketeh china the chinese chicken, you have?
db17k's Avatar
34
Drives: 335ci hold out
2003 S2000  [0.00]
will that bulb fit in the OEM foglight socket? If they offered that kit with 5k bulbs it'd be sick.
"In Soviet Russia car forks you!"
      01-28-2006, 05:48 PM   #20
lux.sh
missing two turbos.
lux.sh's Avatar
poldim, I am pretty certain that there are PLENTY of room to mount that in there. As you can see in pics, there are alot of room to do so. After I saw that, I thought about getting HID kit for the fogs also. I previously thought it'd be tough install cause of minimal space available under there, but it seems like it will be a easy process.
If you can't "hang" around them there, try building a custom mount for it or use 3m double sided tape to stick it somewhere.
Let us know if you go on with this install.
      01-28-2006, 07:00 PM   #21
poldim
Vroom Vrrooooom
poldim's Avatar
Russian Federation
300
Drives: 330i
Here is my 3000K HID Fog Lights Thread
This is the Honda Tech thread that is selling my 3000k kit for $225 shipped.
INFINITUDE USA from Honda Tech
Fitment: H1, H3, H7, H8, H11, H13, H4-Low, H4 Hi/Lo, 9004, 9005, 9006, 9007, D2R, D2S, D2C
Temperature: 3000K, 4000K, 5000K, 6000k, 8000k, 10000k, 12000k, 14000k, 15000K
Low Beam: $210 Shipped
H4 Hi/Lo: $260 Shipped
D2R, D2S, D2C: $220 Shipped
For 3000K JDM Golden Globes, add $15
You can get any of those colors in the H11's.
I will probably place my order tomorrow and they should arrive in a few weeks.
Since you're in Cali, you can order from the first thread for 240 and get them the next day probably.
-Dmitriy
      01-28-2006, 07:37 PM   #22
db17k
db17k's Avatar
34
2003 S2000  [0.00]
Thanks man! that's hot!
