Is This a Safe E91 Rear Jack Point?
01-28-2012, 04:01 PM | #1 |
Rep 78
Got a rubber pad and drilled a hole in it to fit tightly over the rear support bracket. Jacked up the rear from the bracket with my trusty old Lincoln jack. I've never heard that this is a safe spot to lift the rear from. I took a chance and you will be too if you try it this way.
Slipped a tight fitting 6061 T6 aluminum block into the rear hard plastic jack points on either side of the car, slid the jackstands in and lowered the car onto the jackstands. The jack stands are approximately 11 inches at their lowest setting. Add another half inch for the aluminum blocks and the combination holds the rear wheels about 1.5" off the ground. Do this at your own risk, it's potentially quite dangerous. You can hurt yourself seriously or damage your car. Or worse. Comments or suggestions would be appreciated. First picture shows the bracket and surrounding area. The rubber pad is on the far left of the picture. The rubber pad is held in place by the friction of a bolt head attached to the bracket inside a hole in the pad. The second picture shows the end of the floor jack making contact with the rubber pad. There is a steel plate inside the end of the floor jack. The last picture is of the jack stand placement over the aluminum block inserted inside the car's plastic jack point. Also, if someone could tell me how to resize the pictures I'll try to do so to make this easier to read. |
09-09-2015, 02:19 AM | #2 |
Major Private First Class
449
Rep 1,327
Drives: 2010 E90 335i M Sport
I know I'm bumping a really old thread but it's informative. Central jacking points are so damn crucial. I'm sick of doing the side to side stuff with the pads.
2008 E92 335i 6MT: FBO + MMP Silicone Inlets | Stage 1 LPFP | 335is clutch + MFactory SMFW | Custom BuraQ + MHD tune | 3.5Bar N20 sensor [SOLD]
2010 E90 335i M-Sport AT: 5" Stepped FMIC, Stage 2 LPFP - MHD V7 E60 Tune running 100% E85 - VRSF DPs |
09-09-2015, 12:53 PM | #3 | |
711
Rep 3,251
http://www.jackpointjackstands.com/ Expensive for jackstands? Yes! But you can pay enough for safety and peace of mind when lift up a +3500 lbs chunk of metal and glass.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
09-09-2015, 11:30 PM | #4 | |
88
Rep 242
that's my solution unless you dont have room for a 100lb jack. |
09-09-2015, 11:31 PM | #5 | ||
711
Rep 3,251
