Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > The Unlock Button on My Key Fob Won't Work
      01-26-2012, 09:49 AM   #1
kdbryce
I have to return some video tapes
kdbryce's Avatar
Drives: e70 X5M
Has anyone else had this problem? The lock button and trunk button both work fine, but for some reason, the unlock button does not - and of course i lost my spare.
is there anything I can do about this besides buy a new key?
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
      01-26-2012, 09:51 AM   #2
CamelBiscuit
Drives: 11 E92 335i
2011 E92 335i  [10.00]
Don't lock your car and get the best insurance you can.
      01-26-2012, 10:06 AM   #3
2kaccordocoupe
2kaccordocoupe's Avatar
1274
Drives: Former ///M Driver
Take it into the dealer, if you are in good with them they will probably warranty it for you.
In the mean time use the metal blade key in fob to unlock the door.
      01-26-2012, 10:42 AM   #4
kdbryce
kdbryce's Avatar
Drives: e70 X5M
the blade key is the most annoying thing in the world. especially if you have shit in your hands.. i really don't want to spend the $200 for a new key right now
      01-26-2012, 12:11 PM   #5
2kaccordocoupe
1274
I agree it's a pain in the ass. Try the dealer route, worst case they say no right.
      01-26-2012, 12:19 PM   #6
E90Brad
E90Brad's Avatar
26
Drives: SQ5
      01-26-2012, 12:23 PM   #7
summall
summall's Avatar
10
Drives: BMW E90
Does it just not unlock the driver door or all doors? If its the first, it could be the door lock motor instead of the fob. Just a thought. Good luck.
      01-26-2012, 12:47 PM   #8
slowSwede
Sweden
21
Drives: 335 coupe
Just as summall says, does the other remote work?
      01-26-2012, 12:48 PM   #9
2kaccordocoupe
1274
folks, as per the original post the other remote is missing, plus the lock button works so that rules out the motor
      01-26-2012, 01:39 PM   #10
kdbryce
kdbryce's Avatar
Drives: e70 X5M
Last time I had it serviced, I asked about it and they said I would just have to buy a new key for $200.. I doubt they'll warranty it..
i guess 200 isn't much... just thought there might be a quick fix or something
      01-26-2012, 01:47 PM   #11
ndog14
Drives: E90 328xi 6MT
Using the metal key to unlock the car normal cars did some 20 years ago.
      01-26-2012, 02:28 PM   #12
summall
summall's Avatar
10
Drives: BMW E90
May not be a bad idea to buy a new fob and use the old one as spare before everything stop working on your old one.
      07-13-2012, 01:50 PM   #13
Blayneh12
Drives: 330i
Yeah I have the same problem, seems like my unlock button is stuck and feel no click anymore like my trunk and lock button. I guess spare key or go the the dealer...
      07-13-2012, 04:38 PM   #14
orangedawg
31
Drives: 328xi
Exact same thing happened to me this week. Check fuse 57 (I have an 07 328xi). Mine was blown. Replaced fuse (20 amp) and all is good. This is a pretty common problem on these cars. Try changing the fuse first. If that doesn't work, someone on this forum previously mentioned disconnecting battery for at least 15 minutes fixed it for them. But I'd try fuse first.
      07-13-2012, 08:06 PM   #15
Blayneh12
Drives: 330i
I think I figured it out?! A blowin fuze. Now I need to find which one is bad
      07-15-2012, 02:07 PM   #16
orangedawg
31
Drives: 328xi
It should be fuse 57. If not, look at fuse 73. My issue was car would lock fine, and trunk button worked fine, but unlock wouldn't, either on key fob or button on dash. Replaced fuse 57, all is good now. Hope this helps!
      07-16-2012, 09:39 PM   #17
dontburndapig
Puerto Rico
Drives: 2011 E90 335i Sp/Pr/Ppk
Why don't you ask the dealer to re-program your key and then buy a new one? I mean, you lost one key fob...or am I too paranoid?
