Steering wheel not centered?
01-24-2012, 09:40 PM | #1 |
101
Rep 232
Just picked up a new (used) e93, just noticed today that when I hold the steering wheel perfectly straight and centered and drive straight, the car pulls to the right. To drive straight I need to turn the wheel a few degrees to the right inorder for the car to moves straight.
If i drive straight and let go of the wheel, the car moves straight but then again the wheel automatically turns the few degrees to the right by itself. I am assuming because I let go of the wheel and the car drives perfectly straight that its not an alignment issue? Does my steering wheel need to be adjusted so when I put my wheel straight it goes straight? thanks! |
01-24-2012, 10:01 PM | #2 |
Person of Interest
20
Rep 290
Your steering wheel can't be adjusted, it has a spline collar with a notch that is manufactured to make sure steering wheels can only be installed one way, the right way. Even with the way you described it, my guess would still be something to do with wheel alignment.
01-25-2012, 12:10 AM | #4 |
Rep 160
When i hit a curb and bent my rear control arm, im wanting to say it would go straight when i let go but it would be off by probably 3 or 4 degrees. which is quite a bit. Hopefully that's not the problem though for you
'07 328i-Saphire Black Murdeerrrrred-gone
'08 335i-Black on Gold.. work in progress!-JB3-DCI |
01-25-2012, 12:38 AM | #5 | |
57
Rep 1,038
You said that when you hold your wheel straight, the car pulls to the right. Yet at the same time you are saying that in order to make the car drive straight you need to turn the wheel to the right. That just doesn't make any sense. One of your "rights" should really be "left". Which one? |
01-25-2012, 12:54 AM | #6 | |
101
Rep 232
01-25-2012, 12:55 AM | #7 |
101
Rep 232
hmm did you ever end up fixing the problem? did an alignment fix it or did you have to replace your rear control arm?
01-26-2012, 01:04 AM | #9 |
Rep 160
replaced control arm but definitely get it alligned first as the control arm is an expensive part especially installation
01-26-2012, 07:28 AM | #10 |
40
Rep 2,431
Yeah, an alignment with the Steering wheel centered is in order to fix that. Simple job and good to have done once in awhile anyways.
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
01-26-2012, 11:04 AM | #11 |
153
Rep 3,730
When's the last time you checked your tire pressure? Having one wheel off by a few PSI could cause a car to pull. If that doesn't work, get an alignment. If you are having to turn your steering wheel now, you will still have to turn your steering wheel even if you center it.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
