Rust near fuse panel - deal or deal\'s off?
01-23-2012, 07:58 AM | #1 |
Rep 34
Drives: '06 330xi
So I have a handshake agreement to buy this \'06 330xi. It was a FL car that my wife\'s company owns. An exec is leaving and giving up use of it. Getting it at wholesale. Great miles. Plenty options. Deal I can\'t pass up. So this weekend we had the car transported for basically an extended test drive. Already had BMW dealership in FL give it the once over and it checks out in good condition. So, the cig lighters were not working and I checked and replaced a fuse. While doing so, I noticed that there was rust on some sort of bracket that was bracing the fuse panel. Should I be concerned about this? Does it have anything to do with proximity to the ocean? This is definitely not a flood damaged car. These folks were big fans of the beach I know that much. Sand in trunk, armrest, ashtray... Nothing that a good detail won\'t remedy though. For reference, it\'s the bracket in this picture to the left of the bundle of wires. http://www.europeanautosource.com/images/vendors/eas/vehicles/journal/eas/e92m3/ease92m300070.jpg
01-23-2012, 12:17 PM | #3 |
just another bmw douche bag
195
Rep 3,640
if it's a bracket that is not part of the main chassis and it's just a bit of surface rust, then I've seen this before on cars. it's usually a brace behind the dash. Florida is very humid, so you'll see this kind of stuff. As long as the chassis itself doesn't have rust, you should be okay.
get other parts of the chassis checked out, and make sure there isn't any serious rust. There shouldn't be, but you never know. edit, I looked at the pic, and really don't see any rust? it must be really minimal if any. I wouldn't worry about it. |
01-23-2012, 12:46 PM | #4 |
149
Rep 3,552
Rust protection for 2006 and newer models.
For 2006 and newer models, we also provide a 12-year limited warranty rust perforation warranty without mileage limitation. This warranty is for defects in materials or workmanship that results in rust perforation of the vehicle body. This coverage period begins at the start of the New Vehicle/SAV Limited Warranty. |
01-23-2012, 12:48 PM | #5 |
Some dude
92
Rep 1,780
The dash support brackets are not painted, and they're merely bolted to the car. Rust on those parts is inconsequential.
RRT
E92 335i/6MT with stuff and things |
01-23-2012, 01:02 PM | #6 | |
52
Rep 1,746
01-23-2012, 02:06 PM | #7 |
Rep 192
01-23-2012, 02:23 PM | #8 |
153
Rep 3,730
I'd be more concerned it's a flood damaged car you are buying. Check other areas like under the carpet in the trunk for possible debris.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
01-23-2012, 07:24 PM | #9 |
Rep 34
Drives: '06 330xi
Hey thanks Mike. I posted a pic from a site for illustration. That's not from my car. I was posting from my iPhone and didn't see an option to upload my own pic. Yeah it's surface rust on just that support. Thanks guys for all the useful input.
01-23-2012, 07:33 PM | #10 |
138
Rep 2,731
just throwing this out there... it could be a leaking windshield cowling. usually this causes the blower motor fan to rust and fail. the blower motor fan is close to the fusebox. i doubt it is this though because the water usually passes through the opening for fresh air coming from the microfilter, perhaps there is water intrusion where the wiring harness passes thru the firewall. long story short, if it rains hard, check for wet carpet in the passenger floor area.
01-24-2012, 05:16 PM | #12 |
Some dude
92
Rep 1,780
Nope, that brace rusts simply because it's unpainted/uncoated from the factory. It happens to all of them eventually, and it's merely surface rust. If you live near the ocean or in a humid climate, you may see more rust on those parts, but it's completely inconsequential to the rest of the body/chassis.
RRT
