BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > 335d fuel pump audible?
      01-22-2012, 02:39 PM   #1
AJT
37
Drives: 2020 M2C
'11 335d, ~2k miles on it. Can you guys hear your fuel pump (albeit just barely) if you're at idle and the stereo isn't on? This may well be normal with a hpfp, so pardon the newbie question if so.
I did try to search and didn't find anything FWIW.
      01-22-2012, 03:20 PM   #2
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Uhhh..no
      01-22-2012, 05:39 PM   #3
maswastage
Resident Diesel Junkie
maswastage's Avatar
56
Drives: 2010 AW 335d
How do you know it's your fuel pump you're hearing? Can you describe the sound?
      01-22-2012, 07:24 PM   #4
AJT
37
Drives: 2020 M2C
Good question, guess I'm assuming. I have friends with very high hp cars that have large aftermarket (and noisy) fuel pumps, and this is a similar noise from a pitch perspective, though not nearly as loud. It sounds like it's coming from the rear of the vehicle (noise seems to emanate from the inside, windows all up), with a continuous, relatively high pitch. It's not very loud at all, if the radio is on at any volume I don't hear it, but I'm in that phase with a new vehicle where I'm still sensitive to all the sights, sounds, etc.
      01-22-2012, 07:25 PM   #5
hotrod2448
grand poobah
hotrod2448's Avatar
Drives: F80 M3, F10 535i
2011 335d  [0.00]
Are you talking about the electric pumps in the cell or the mechanical pump under the hood?
Either way I wouldn't be so sure it's the fuel pump you are hearing. There are quite a few cooling fans for every thing from control modules to the ECU in these cars that you may be hearing.
      01-22-2012, 07:32 PM   #6
AJT
37
Drives: 2020 M2C
The noise comes from the rear of the car. I'm probably just being a hypersensitive newbie about it. It's an extremely faint sound.
      01-23-2012, 06:18 AM   #7
hotrod2448
grand poobah
hotrod2448's Avatar
2011 335d  [0.00]
If I recall correctly there is a fan back there to cool the audio amp as well. Might just be an L7 item, not sure.
