01-11-2012, 02:04 PM | #1 |
429
Rep 4,650
♦ Sonic MS | APEX ARC-8 Lightweight Rotary Forged Wheels
Sonic Motorsports 1045 West El Camino Real Mountain View, CA 94040 tel: 650-733-6506 fax: 650-691-9009 email: info@sonicms.net APEX Race Parts - ARC-8 Rotary Forged Concave Wheel Set for BMW Presenting the ultra light, yet affordable one piece rotary forged APEX ARC-8 Wheels. These wheels already come in 1M Coupe specific widths and offsets, so no spacers or fender adjustments will be required. They are made to clear BBKs standard and utilize a rotary forged inner barrel - this manufacturing process provides an exceptionally light weight wheel for a concave mesh design. These wheels are fully VIA and JWL certified with a load rating of 1550lbs. - Comes with carbon-look APEX center caps - Accepts OEM Roundel center caps - Install using your factory lugs or a stud conversion - Accepts wheel spacers including 5mm thickness, while remaining hub-centric - OEM TPMS compatible Rotary Forged / Flow Formed Cast - Technical Information This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel. During Flow Forming, the pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. The resulting grain structure within the alloy of the wheel is linear, flowing in a single direction. Finishes Available: - Hyper Silver - Anthracite - Hyper Black - Satin Black Recommended Fitment for the E82 1M Coupe. Staggered 18x9.5 ET22 (Est. 19.20 lbs) 18x10.5 ET27 (Est. 20.45 lbs) 265/35/18 285/35/18 Square (Requires Front Camber Plates) 18x10 ET25 (Est. 19.95 lbs) 275/35/18 We also offer full rim and tire packages including OEM TPM sensors. We utilize the Hunter Road Force GSP9700 Balancer and “Touch-less” Auto 34 Mounting Machine to mount and balance your rims and tires safely and effectively, without risking any damage to your new investment. Recommended Tires: *Please click on link for more information on the tire, including pricing. 18 INCH STAGGERED SETUP Continental ExtremeContact DW Hankook Ventus V12 evo K110 Hankook Ventus R-S3 Bridgestone Potenza S-04 Pole Position Michelin Pilot Super Sport 18 INCH SQUARE SETUP Bridgestone Potenza RE760 Sport Continental ExtremeContact DW Hankook Ventus V12 evo K110 Hankook Ventus R-S3 Bridgestone Potenza S-04 Pole Position Yokohama ADVAN Sport Michelin Pilot Super Sport Dunlop Direzza Sport Z1 Star Spec Pricing: 18 inch Staggered - $1316.00/set 18 inch Square - $1296.00/set *Note - Pricing above does not include shipping and/or sales tax (CA 8.25%), if applicable. For best pricing and ordering information, please call me at 650.733.6506, email at cal@sonicms.net or shoot me a PM. Store Hours: Mon-Fri : 10AM-7PM PST Sat: 12PM-5PM PST Payments: We accept all major Credit Cards, in addition to PayPal and Certified Cashiers Checks / Money Orders. We also offer professional on-site installation services for customers local to the SF Bay Area. Please contact us directly for more information. |
05-08-2012, 01:24 PM | #22 |
429
Rep 4,650
