Bulb is good but still not working .. Please Help!
01-07-2012, 04:21 PM | #1 |
9
Rep 33
I began getting a "Left taillight malfunction" warning. The warning comes and goes but the light simply doesn't work. I determined that it's the highest light in the headlight assembly - the same one as the brake light but it comes on with all the lights and half the brightness of the brake light.
The bulb is good and it works when I apply brakes, so obviously I know it's good. But when I let off the brakes, if the lights are on, the right side stays illuminated but the left doesn't. Anyone have any idea how to fix this?? It's a 921 bulb, not one of the LEDs. Last edited by ///Chris; 01-07-2012 at 04:34 PM.. |
01-08-2012, 01:02 PM | #2 |
103
Rep 2,783
It may be the socket. My passenger side turn signal socket was burnt. Take out the bulb and take a look on the inside to see if the contacts are burnt or rusted/rotted. By the way, they are cheap to replace, about $8 at the dealer. NO CUTTING OF WIRES REQUIRED.
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
01-08-2012, 01:11 PM | #4 | |
9
Rep 33
Thanks for the reply. I did look at the socket and it looks like new. Plus the bulb/socket works when braking, so I have no idea what's going on. |
01-08-2012, 01:17 PM | #5 | |
9
Rep 33
I also tried switching the lights with the other side, which works properly, and still the running light doesn't come on so I'm wondering if there's a fuse just for that side's running light somewhere? And finally, the warning light no longer comes on but the running light is still out ... so I'm thoroughly confused |
01-08-2012, 01:18 PM | #6 |
103
Rep 2,783
For the hell of it, try switching bulbs around.
01-08-2012, 01:19 PM | #7 |
103
Rep 2,783
Oh, wow, that is weird.
01-08-2012, 01:20 PM | #8 |
103
Rep 2,783
Ok, did you mod the lights in any way? If so then there is your problem.
01-08-2012, 05:36 PM | #9 |
9
Rep 33
Nope, they're bone stock ... here's a pic:
It's the top part that doesn't light up (except when I brake), but it won't come on when I unlock the car, whereas the driver side does |
01-08-2012, 05:55 PM | #10 |
252
Rep 1,157
do you have a multimeter or circuit tester? see if there is voltage at the socket. maybe the terminal inside the socket is a little bent back or something that is prevent contact.
01-08-2012, 08:38 PM | #11 |
169
Rep 12,680
Drives: like an asshole
Buy a whole new light assembly its 20-30 bucks. It'll save you the headache
01-08-2012, 08:41 PM | #12 |
253
Rep 7,089
Drives: '06 AW 330xi
There was a service bulletin out for a faulty bulb holder. But I think your problem is with the lines? They can't be replaced. At least to my knowledge.
01-09-2012, 05:43 PM | #13 |
9
Rep 33
Thanks everyone for the help.
So I went to the dealer and the service dude comes out like he's in a huge hurry and I'm a big waste of his time and takes one look at it and says condescendingly, "Your light's not out, that's a European fog light" and he walks away. Anyway, I get him back and show him it's definitely not a fog light and he says I'll have to bring it in .. so I guess I'll try replacing the fixture and hopefully that fixes it cause I'm definitely not gonna let BMW charge me probably $400 to fix a "European fog light" |
01-09-2012, 06:35 PM | #14 |
143
Rep 2,284
01-09-2012, 06:55 PM | #15 | |
74
Rep 1,035
Its most likely a bad bulb holder or worst case a bad FRM. Can you get me the part # off of the sticker on it? There is a white sticker on the bulb holder, I can tell you if its a newer or older style. Can you turn on the lights take a pic and show me which one you are seeing on and off on both sides. |
01-09-2012, 07:59 PM | #16 | |
253
Rep 7,089
01-09-2012, 10:22 PM | #18 |
369
Rep 8,693
Drives: 06 330i
sounds like a two stage bulb and one is out.
01-10-2012, 06:45 AM | #19 |
74
Rep 1,035
01-10-2012, 07:32 AM | #20 |
49
Rep 752
I'd be willing to bet it's that service bulletin. I had mine done too.
2001 Chevy 2500HD Duramax
2003 VW Jetta TDI 2012 BMW F800GS 2024 BMW M2 BSM 6MT Carbon Package |
01-10-2012, 07:40 PM | #21 | |
9
Rep 33
01-15-2012, 03:27 PM | #22 |
74
Rep 1,035
Something is not right. That light on the left upper part of the taillight is NOT supposed to come on with just the lights on. That is the brake light. I'm still guessing there is something wrong with that bulb holder.
