      01-04-2012, 11:33 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Smile >>HP Autosport<< Evolution Racewerks 1M Charge Pipe - special price in November!
-Now available for the 2011 1M N54T Engines!
-Increase throttle response and decreases turbo lag.
-Compatible with factory diverter valves or aftermarket factory style diverter valves.
-Lightweight High Grade 6061 Aluminum Piping.
-Throttle body matched 3" piping.
-Retains factory style o-ring throttle body lock flange. Precision CNC machined throttle body flange ensures leak free connection to throttle body. -Quick and easy connection and disconnection to throttle body. Ideal connection compared to the silicone hose and hose clamp connection found in all other aftermarket diverter valve upgrade pipes available in the marketplace.
-Precision CNC machined MAP sensor flange ensures leak free connection.
-Diverter Valve Charge Pipe features beaded ends and T-bolt clamps to prevent intercooler piping from coming off from boost.
-Factory diverter valve sound baffle, which causes turbulence in the factory pipe, is removed.
-Optional Type III Hard Black Anodizing (for stealth and OEM look). Hard anodizing helps improve durability of intercooler piping. Resists bent or dented piping.
-Includes all hardware needed to install.
-Includes all hardware for complete installation.
-Developed under the harsh conditions of racing on our 135i Race Car.
-Optional TIAL Q Blow Off Valve available in 5 different colors (black, polished silver, red, blue and purple).
-Optional Synapse Synchronic Blow Off Valve now available!!!
-Optional HKS Super Sequential Blow Off Valve now available!!!
-Limited Lifetime Warranty.
Retail is $299.95
Sale: $279.95
ORDER HERE: http://hpashop.com/Evolution-Racewer...e-ER-CP-1M.htm
Silicone spray is great to have around when working around O-rings and silicone couplers:
https://amzn.to/2PagAOk
      01-15-2012, 09:47 PM   #2
1'M Blue
Oman
254
Drives: 1M
Noob question.. does fitting this require any form of engine tuning/calibration ? or is it a (remove old peice and fit in new peice and your done) ?
      01-17-2012, 03:36 PM   #3
HP Autosport
Drives: F80 M3
R&R only.
No software upgrade required.
      06-30-2012, 04:59 PM   #4
ozinaldo
ozinaldo's Avatar
Portugal
115
Drives: 1M
Should I still consider this if I opt for the ETS direct fit 1M FMIC? That FMIC kit includes charge pipe as well but never heard any comments from anyone on how it works.
      07-01-2012, 12:34 AM   #5
HP Autosport
Drives: F80 M3
The FMIC comes with a new discharge pipe as part of the kit, which replaced the OEM plastic one, but it is not the same as the charge pipe.
The ER charge pipe will still replaces the flimsy oem piece and make the car more reliable.
      07-01-2012, 11:09 AM   #6
ozinaldo
ozinaldo's Avatar
Portugal
115
Drives: 1M
Thanks.
      09-19-2012, 11:21 AM   #7
HP Autosport
Drives: F80 M3
1M
Anodized black using stock DV with no meth bung in stock!
Anodized black using Tail Q BOV(black) with no meth bung in stock!
      09-19-2012, 11:21 PM   #8
golo
Drives: E91 335i
how much for shipping to New Zealand? thanks
      10-24-2012, 01:22 AM   #9
HP Autosport
Drives: F80 M3
PM sent!
      04-18-2013, 04:04 PM   #10
MrBimmer
Rated M
MrBimmer's Avatar
Drives: 1M
What's the difference in sound with the baffle removed?
      04-18-2013, 04:37 PM   #11
HP Autosport
Drives: F80 M3
Using OE DV's, not much change in sound.
      06-09-2014, 09:39 AM   #12
Quo
Drives: 1m Black 2012
Looking for one of these myself, In black, wont be using meth at all so without bungs. Probably use forge diverter valves, which I can get here so just a price for the pipe. Could you give me a price shipped to the UK please.
      06-09-2014, 03:05 PM   #13
HP Autosport
Drives: F80 M3
For the exact shipping charges it is best to select the options and add the item to cart, then enter your information with the shipping method you like.
http://www.hpashop.com/Evolution-Rac...e-ER-CP-1M.htm
      06-20-2014, 01:49 AM   #14
Quo
Quick question before I order one of these, if you order it with the Tial BOF does the price include the flange as you can not select flange and BOF. Thanks
      06-25-2014, 05:35 PM   #15
HP Autosport
Drives: F80 M3
Yes, it does. The CP will be fully assembled with the BOV on it.
      08-07-2014, 01:39 PM   #16
kookieshk
kookieshk's Avatar
Hong Kong
17
Drives: AW BMW E82 1M
Just got into limp mode from a hot summer night!
I have yet to figure out whats wrong, but I am suspecting that it is the charge pipe!
If I replace my charge pipe, what will I need and how much will shipping be to Hong Kong?
Thanks!
      08-14-2014, 12:04 PM   #17
HP Autosport
Drives: F80 M3
Thanks!
PM sent!
      08-19-2015, 10:19 PM   #18
HP Autosport
Drives: F80 M3
bump
      11-25-2015, 01:08 PM   #19
HP Autosport
Drives: F80 M3
We will beat any ER dealer's quote
      12-14-2015, 10:38 AM   #20
HP Autosport
Drives: F80 M3
bump
      01-12-2016, 07:32 PM   #21
HP Autosport
Drives: F80 M3
bump
      02-07-2016, 02:42 PM   #22
HP Autosport
Drives: F80 M3
bump
Search this Thread:
Advanced Search
