Need help please: sparked my alternator and now getting rough idle
01-04-2012, 01:49 AM | #1 |
40
Rep 413
I removed my alternator to give me more room to work on replacing the oil filter stand gasket and did not disconnect my battery, lesson learned, as I was putting the alternator cable back on, it sparked. When done, car still started fine and everything had power, I shut the car off. I then started it again to move the car and it was shuddering very hard. Getting code P1554. Any help is appreciated. I checked all big fuse under the glove and they are fine. Rough idle, I'm thinking maybe I need to clean the MAF sensor. I cant think of anything else it could be, I made sure all plugs are connected.
01-04-2012, 02:00 AM | #2 |
49
Rep 752
clean your vanos. could also be intake camshaft sensor
P1554 = Idle Speed Control Throttle Position Basic Setting Conditions not met
2001 Chevy 2500HD Duramax
2003 VW Jetta TDI 2012 BMW F800GS 2024 BMW M2 BSM 6MT Carbon Package |
01-05-2012, 12:10 AM | #4 |
40
Rep 413
I got a different code after I cleaned the vanos, p0341 which is related to camshaft. I made sure the connection was tight, restarted and idled fine then car died again. After few starts and dying I got another code p0015, still related to camshaft. After researching, I read that low battery can give a faulty camshaft code. I think when I sparked the alternator, the alternator is no longer working. Where can I find the alternator fuse or am I doomed and will need a new alternator?
01-05-2012, 02:06 AM | #5 |
49
Rep 752
I think it's your crankshaft sensor to be honest.
01-05-2012, 06:36 AM | #6 |
Diesel Fitter
36
Rep 424
Drives: 335d m-sport LMB
It could cure itself, hopefully it will.
01-05-2012, 10:25 PM | #7 |
40
Rep 413
Think I found the problem to be alternator is toast. I couldnt find an alternator fuse so I will be bringing the alternator to get tested. I have a scan gauge that plugged into the obd2 and voltage shows 11.7, as soon as I start the car, it drops to 10.1 and engine struggles and dies. Voltage never picks back up. I've read that low battery can set off camshaft sensor engine fault, so its not necessarily that the sensor is bad.
01-05-2012, 11:24 PM | #8 | |
103
Rep 2,783
If no codes are being thrown use Chevron Techron fuel injector cleaner (concentrate). It solves rpm fluctuating upon cold start-up. Also, for most BMW problems start off by scanning your car with the Peake Research Tool. It contains the actual BMW codes. If you want to register a newly installed battery for free (just buy a $10 cable) and google/download BMWLogger
01-06-2012, 10:05 PM | #10 |
40
Rep 413
Okay turns out alternator and battery is fine. I reset the codes and after couple start, car rough idling and then stalling. I get code P1553. I researched and found this could be either the camshaft position sensor or vanos solenoid that needs to be replaced. I have pulled and cleaned both vanos solenoid with compressed air and swap then when installing. That didnt help. Anyone else have this code and know which sensor to purchase? I really dont want to purchase both camshaft and both vanos if its really just one that needs to be replaced. Or is there a way to check the sensor with the voltmeter?
01-08-2012, 10:53 PM | #11 |
40
Rep 413
I dont have an IBS sensor in my car :/ its a 2006 325i. I dont see anything on the positive terminal and I have a harness laying around thats not plugged into anything. Is all e90 suppose to have an IBS sensor?
And wouldnt my car at least start and stay running until the battery is low. What its doing is struggling to start and when it finally starts up, it idles rough for few seconds then just stalls. Anyone with same symptoms? Code Im getting is P1553, but I've read that others got that code to but are still able to drive with no symptons. Any help please? |
01-09-2012, 01:54 AM | #12 | |
103
Rep 2,783
01-09-2012, 02:11 AM | #13 |
103
Rep 2,783
Take a look at this too http://tis.spaghetticoder.org/s/view.pl?1/10/97/46
01-09-2012, 11:05 PM | #14 | |
40
Rep 413
01-09-2012, 11:08 PM | #15 |
103
Rep 2,783
#3 is not necessary (i think), but your ibs is marked as #1.
01-29-2012, 05:01 PM | #17 |
40
Rep 413
Okay, reporting back. Finally had time to work on the car. Scanned car again just to make sure of what cel I got and I got a cel P1553. I cleared the code and replaced both Cam Adjuster Solenoids(referred to as Vanos I think) and car had a to struggle to start, but thats due to sitting out for few weeks and it started and idled fine. Car ran like normal. I figured the vanos was maintenance anyways as I've read storied about some going out as early at 20K or 60K and my car is almost at the 100K mark. Thanks for all the help, hopes this help someone out later on.
