      12-29-2011, 05:22 PM   #1
RaptorKTM
RaptorKTM's Avatar
Drives: 1 M Coupe
2011 BMW 1 M  [0.00]
Akrapovic Wireless Kit Issue
I have run about 400 miles on my Akrapovic Evolution System with Downpipes and the ESS tune and it has been running amazing to say the least. No hiccups, just pure fun. I just finished it all up by actually have the wireless system all hooked up. I was running the car prior with the flap just kept open. After attaching the wireless kit however I am unhappy. The changes in the sound are there and the wireless kit works perfectly however when set to open flap (loud) it is really not as aggressive as it was before the actually electronics were hooked up. What could be changing the sound when set to loud?
      12-29-2011, 06:32 PM   #2
Alpine*
Alpine*'s Avatar
Australia
1281
Drives: M2 G87
I have the same setup, minus the DPs, but have no butterfly.
Maybe the flap doesn't open to 90 degrees and as such still has some restriction on exhaust flow
I guess the only way you could tell is dyno with and without the butterfly, that would be a pain though.
      01-02-2012, 11:22 AM   #3
RaptorKTM
RaptorKTM's Avatar
Drives: 1 M Coupe
2011 BMW 1 M  [0.00]
bump
      01-02-2012, 03:48 PM   #4
Plautos
Plautos's Avatar
Brazil
7
Drives: 1M
The flap was installed, but not connected to the electric system neither to the vacuum line?
Probably you have a vacuum leak...
      01-23-2012, 01:44 AM   #5
M3EST
Rear wheel drive fanatic
M3EST's Avatar
51
Drives: M3 E30-1M-M4
1987 BMW M3  [0.00]
2011 BMW 1M  [10.00]
Check it in your garage again.My flap opens and closes perfectly and the sound change is incredible.
      02-01-2012, 12:31 AM   #6
GTR_Steve
United Kingdom
9
Drives: BMW 1M Coupe
The valve is spring fail open, vacuum to close (which disappoints a little as it is noisy on start up until vacuum takes hold) hence vacuum leak would not cause this issue. The valve can be clearly seen through the left hand tail pipe. If closed either the spring has failed on the actuator or you may have the vacuum tubing reversed on the solenoid (in the boot)
      02-01-2012, 10:40 AM   #7
///M1
///M1's Avatar
Drives: Many
Hah, that explains it. Just installed my Akra and was wondering why upon first crank it sounds louder before calming, totally makes sense!
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
