Cold Start Ticking, not metallic
12-29-2011, 03:56 PM | #1 |
52
Rep 1,746
So yesterday my car made a ticking noise for the second time since I have owned it (07/11), it is an 07 328xi. The conditions were the first cold start of a nippy day, about 29F. Today it did not happened, but it has happened before. Same conditions, cold start of a day that was just below freezing. Sorry for the quality, taken on my Droid Incredible. The ticking is from somewhere near the pulleys on the front of the engine block, it is NOT a metallic noise.
12-29-2011, 07:09 PM | #5 | |
52
Rep 1,746
Wouldn't it tick all the time, not just on cold starts? The days I've cold started above the freezing point I have never gotten it. Its the first cold start of a day below freezing. Also, the lifters are the metallic tick, which this is not. |
12-29-2011, 07:37 PM | #6 |
28
Rep 89
Sub'd
Same thing happens with mine. On cold days (roughly around 30-35 degrees) I head the tick upon starting. When it warms up it usually goes away, but there have been times where it is still there. I wonder if I should take it in |
12-29-2011, 08:06 PM | #7 |
52
Rep 1,746
If it is the lifters as suggested, I read that driving at low rpms for short distances exasperates the problem overtime. Both times it happened to me the one trip was an hour and the other was 15 minutes, both times I surpassed 3.5k on the tach during the drive. To make sure the engine warms up.
12-30-2011, 02:59 AM | #9 |
45
Rep 472
that sounds like the lifter ticking. I've had the same thing.
if not taken care of it will progressively get worse and more frequent. take it in and get it documented it people even if you're planning to sell it. think about the next owner who might buy it not knowing it. if you get it document it you have much more chance of getting it fixed even after warranty expires. |
12-30-2011, 09:37 AM | #10 | |
52
Rep 1,746
I thought the lifter ticking was related to all cold starts, not cold weathet cold starts. Also, all other videos I have seen suggest the ticking is near the lifters, my tick is on the front of the engine block in the pulley system. And it was a metallic tick, which I have stated multiple times this is not. As for the next owner, it's a used car. Do you expect a 6spd bimmer owned by a hot-shot 20 year old to not have problems? I'm trading my car in bcz I don't want some stupid teenager getting it and complaining. Think about the life of the typical 3 series: first it is leased for 2-4 years, then a young, male professional buys it and thrashes it for awhile, then a 16 year old gets it, followed by another 16 year old, then another, etc till the car dies. Today I plan to have a real video camera to record the ticking if it happens today. |
12-30-2011, 12:21 PM | #12 | |
52
Rep 1,746
Today when I cold started the ticking did not happen, it was 44F outside. |
12-30-2011, 12:26 PM | #13 |
7478
Rep 10,120
It's a lifter ticking. Had that issue and BMW first replaced the lifters, ticking came back so then they replaced the head. Car runs smooth as silk now. If you are out of warranty then you might have to pay for the repairs out of pocket. And I believe (might be wrong) but it's about $4k to get it fixed.
12-30-2011, 12:27 PM | #14 | |
7478
Rep 10,120
The shop didn't do anything, this is a common issue with the N52 engine. I believe they fixed it in the 2010 and up models. |
12-30-2011, 12:32 PM | #15 |
50
Rep 753
It's lifter tick. Oil is too thick in the cold to get pumped up. Goes away once it warms up. Use a slightly thinner oil, or use a good additive. So far I have been successful with Molyslip, but I'm sure there are other products out there that would help with the problem too.
Perminantly fix is fairly expensive. There is a sticky on this in the N52 forum with a very long thread. no need to keep this one going. |
12-30-2011, 02:01 PM | #16 |
27
Rep 600
This is definitely the lifter ticking sound. My 2008 328i did this (though often and randomly) and the dealer swapped the head out for me. That fixed it for good.
Jay (in San Antonio, TX)
2014 428i coupe, mineral gray metallic with black interior, black ash trim, luxury edition. |
12-30-2011, 06:09 PM | #17 | |
52
Rep 1,746
I am not looking forward to new heads. |
12-30-2011, 06:15 PM | #18 | |
19
Rep 411
12-30-2011, 06:36 PM | #20 |
52
Rep 1,746
They're not new. The only thing new is a valve cover gasket and hex bolt. And a bmw dealer did the rebuild. And both ticking occurences were after the rebuild, but may have existed under previous owner.
12-30-2011, 10:56 PM | #22 |
19
Rep 411
Since you are out of warranty, I highly doubt they will fix it under goodwill. The entire job may cost up to $4k or more depending on the dealer. My SA quoted me $4k just for the head cylinder replacement. If my lifters had not been replaced prior to my warranty expired, it would've been added in addition to the $4k. I would say close to $5.5k for the entire job. But luckily, both cylinder heads and lifters were replaced under warranty. Either way, take it to the dealer ASAP to have them take a look at. Also show them the video you have of the ticking sound. They will know exactly what it is....
