Keyless Start Question
12-25-2011, 07:43 AM | #1 |
61
Rep 334
Hi everyone.
Merry Xmas. Is there any way around to not having to put the key in the slot if you haven't got comfort access and still be able to start the car by pressing the start button? I have already read that if you put your key in and start the engine and then take the key out you can restart the engine without putting the key back in if you press the start button within 5 seconds of taking the key out. This is not my question! Is there any way around not needing to put the key in at all to start the car? Are there any modifications that can be made to the car or is there anything you can install to get around this? |
12-25-2011, 08:46 AM | #2 |
121
Rep 1,568
I really don't think you can without comfort access. CA includes transmitters and antennas to scan the car for the CA key. It prevents you from locking your car with the key in it (tested this out by accident last time I was at the airport awaiting the shuttle - car beeped at me and it quickly unlatched the trunk right after I closed it)
12-25-2011, 09:10 AM | #3 | |
61
Rep 334
Here is a link to a kit advertised to be able to allow you to have keyless start. The question is will it work in our BMW's which already have start/stop buttons. See link please.http://www.ultimatecarparts.co.uk/ke...FegmtAodmHgrlA |
12-25-2011, 10:20 AM | #4 | |
thats what she said...
23
Rep 167
my friend has the feature in his nissan 370Z. he can have his key in his pocket, and open the car door with a button ouside the door. and then sit down and start the car without having a key slot. im sure this is possible, but the question is; how much modification is required? happpy holidays, Ryan
2008 335i Alpine White // 15% tint all around // PROcede Rev 3, 11-1 maps // Vishnu DCI
12-25-2011, 10:53 AM | #5 |
33
Rep 655
it could be possible, I mean if the car allow you to start the car w/out key seconds after you started the car with the key, why not code the car to make it believe the key was there.
But then, every one could steal your car. |
12-25-2011, 11:03 AM | #6 | |
61
Rep 334
What kind of place/technician would do this kind of work? |
12-25-2011, 12:40 PM | #7 |
165
Rep 7,433
I don't see how this would bypass the level of encryption the key has when it pairs with the computer when it goes into the slot
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
12-25-2011, 12:59 PM | #8 |
61
Rep 334
Maybe if you have the key on your person, which you would. Surely other cars that are able to use this system still have an encryption chip in the key which has to be recognised to allow the engine to start!
12-25-2011, 09:22 PM | #9 |
Parrothead
137
Rep 1,232
Drives: E90 M3
It looks like this system works similar to a remote start, if you look at the photos it has a wiring diagram and what looks like a secondary key placed under the dash, the problem with this type of system or any other remote start using a second key is just that, you are leaving a key in the car.
it says it uses the central lock to enable or disable the system so all i can figure is that the module uses a power line and when the car gets the proper lock/unlock signal and passes the power through the line it activates the bypass All i know is that many installers won't mess with the ignition system on our cars and even a proper remote start is costly so i can only imagine what the cost here would be, nor is there any indication of the quality of the system. Sorry not trying to burst your bubble just letting you know what I can see or have been told.
|e46 M3 Stahlgrau/Red| - Sold |E92 335i BSM/Saddle| - Sold |e90 M3 Space Gray/Fox Red/6MT| See Garage for Mods |
12-25-2011, 11:48 PM | #10 |
8
Rep 172
Interesting that it would need a fake key in the car for the remote start. On my current Ford Remote Start System, which is a non factory part but is still a Ford part I ordered through and had installed by my dealer, it uses a ring device that sticks around the ignition key (but is hidden) to send the key signal to allow the car to start. The device is non functional unless the remote start device activates it, so even if the Fusion Hybrid had a push button start, it wouldn't allow for the car to be stolen (well, unless the thief found the box in the dash and somehow made it send the signal, but I doubt that would be very easy).
You'd think the remote start manufacturers could come up with a similar solution for the BMW keyless system. As far as the car is concerned, it's just another key, it doesn't have a camera that looks at it to make sure it optically looks right. Just stick an antenna on the slot but in the dash and have the remote start device tell it what to transmit. When the remote start device isn't being used, there wouldn't be a signal telling the car a key exists, so the push button ignition would be refused. |
01-19-2012, 07:28 PM | #11 | |
Rep 13
This might help
Hey this might help, it does involve a remote starter. Any good installer should be able to do this. The parts you will need are an Fortin INT BMW2 and an Fortin Evo Can + a remote starter. The Int Bmw2 interfaces with your factory ignition. It allows you to remote start and drive away with out putting the key in the slot. This only works if unlocked with the remote starter. http://www.ifar.ca |
01-20-2012, 08:53 AM | #12 | |
55
Rep 3,606
01-20-2012, 06:03 PM | #13 | |
61
Rep 334
01-21-2012, 08:24 AM | #14 |
Rep 192
In theory you could take the slot you put your key in and remove it and place it back under the dash and put a spare key in it. Then you could put a dummy slot there. You would still lock your car with the key but it would always be active so if you didn't lock the car someone could go in and drive away. You can try this out by leaving a key in. I know that you will still have to hold the brake to start.
This would do exactly what the link above would do. |
