OK, I have no idea what just happened....
12-24-2011, 02:27 PM | #1 |
Rep 27
Hi guys,
Not sure what just happened I was driving down interstate 95....I went to pass a few people I was probably going about 105mph (dont judge me, I had to get around these people they were going 2). Once I get around I hear a sound that takes me back to the multiple times that I have gotten a flat tire. I scream and then proceed to pull over. I get out the car check the tires, none of them are flat and the FTM did not go off. So I thank God , hoping it was just my imagination. So then I pull back on the highway and go around 70, about 4 miles up the road I hear the noise again. It only lasts for a minute, then stops. I just slow down and drive to my parents because I am only 2 miles away and I look at the car, the tires, undercarriage. No visible issues. What gives?! Anyone heard of an issue like this? Sounds like a flat tire, like you are riding on a rim, but nothing is flat. Any help or insight is much appreciated.
12-24-2011, 02:58 PM | #4 | |
Came to the N55 Darkside
1112
Rep 12,740
12-24-2011, 03:08 PM | #5 |
27
Rep 566
12-24-2011, 03:12 PM | #6 |
1112
Rep 12,740
12-24-2011, 03:23 PM | #7 |
73
Rep 1,770
12-24-2011, 03:27 PM | #8 |
1112
Rep 12,740
12-24-2011, 03:32 PM | #9 |
74
Rep 569
You said not to judge, but I'm judging. Slow down, buddy. You're gonna kill someone. You never "have" to pass anyone. Your life and the lives of others... they're worth infinitely more than the two minutes you tried (and failed) to save.
Everyone likes to drive fast, we have great cars for it. That's what the track is for. I-95 is not an appropriate venue. |
12-24-2011, 03:38 PM | #10 |
252
Rep 1,157
maybe one of the fender liners, bumper or underside panels is loose and only flaps at speed? window/sunroof seal pulling off/open at speed? is your hood latch down fully?
more info... vibrations? if so where were they felt? steering wheel? shifter? seat of the pants? any stability issues? and issues with with air inside the car as in did you feel any large air pressure changes? |
12-24-2011, 03:44 PM | #12 |
1112
Rep 12,740
Poor guy/ gal (assuming it's a gal due to the screaming when it happened ) but seriously...now I am starting to feel bad here...allow me to clarify things.
Listen, we're not trying to rag on the OP, I for one just care really. I would hate to see anybody get hurt, especially around the holiday season, or worse yet, killed over something that is completely preventable. Have a Happy Holiday and best wishes for a SAFE and prosperous New Year to you and your family Erin. Good luck in resolving your issue too- I'm sure some knowledgeable soul will chime in with the solution. |
12-24-2011, 03:50 PM | #13 | |
27
Rep 566
Well put.. Last thing anyone want is a ruined Christmas. Take it easy and Merry Christmas. If the problem keeps happening, take it to the dealer and ask |
12-24-2011, 04:26 PM | #14 |
Rep 27
Yes, I am a woman. Merry Christmas to you as well. Back to the subject at hand.
@avocet: I took a peek under the car if I could see or feel anything that may be loose, I might not have been able to reach everything. However, I did not see or feel anything. I will get it on a lift to check everything on Monday. There were no vibrations, just the thump thump sound of a flat. I did not feel a change in air pressure or loss of stability or control. It was really odd.
12-24-2011, 04:29 PM | #15 |
74
Rep 569
In that case, you are already handicapped at driving, so please slow down.
I KID, I KID! Srsly tho... slow down. At that speed, suppose you were in an accident that someone ELSE on the road caused by their own bad driving -- you would still potentially be on the hook for serious criminal and civil penalties along with the practical consequences of whatever physical destruction took place. I used to be a prosecutor... if I had a case come to me where someone was driving 100+ and there was (god forbid) loss of life involved, I'd automatically charge reckless homicide. There's a presumption that you're at fault when you're going that speed. It IS. NOT. WORTH. IT. |
12-24-2011, 04:34 PM | #16 |
138
Rep 2,731
on another car i had once forgotten to tighten the lug nuts and swore it felt like i was driving on a flat. couldn't tell they were loose by looking, plus with the weight of the car on the wheel it didn't move or anything when i kicked the thing. i had to actually try tightening the lugs to realize they weren't torqued.
our bmw wheels are hubcentric, so theoretically the weight is resting on the hub and loose lug bolts wouldn't cause the same effect until they backed out enough for the wheel to clear the lip of the hub, but who knows, check those fuckers. |
12-24-2011, 05:04 PM | #17 | |
141
Rep 2,217
12-24-2011, 05:23 PM | #18 | |
Rep 27
I will check that. Can change in temperature cause lugs to loosen? Because my wheels have not been touched since last month when I got an oil changed and I had them take a peek at my brakes. They removed 3 of 4 wheels, one of the wheels was pretty much seized on there. I have an appointment to go back after the new year, I might try to get in there sooner.
12-24-2011, 05:27 PM | #19 |
252
Rep 1,157
ah the plot thickens!!!
whenever something goes sideways, the first thing to ask is "what was recently messed with"! does turning have any effect? side loading a loose wheel while moving generally causes symptoms to manifest themselves. |
12-24-2011, 06:09 PM | #21 |
213
Rep 1,782
Maybe its road debris. On a side note I don't see why you guys care about her going 100. It's not a big deal in these cars. If it was a civic or my friends 2002 camry then it would be crazy. Seriously I almost soiled myself in that car.
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
12-24-2011, 06:21 PM | #22 |
Rep 30
Was the frequency different at 70 vs 105?
No? Then I think you have a rod bearing letting go. See if you can replicate in the driveway. If it was THAT loud, and caused no feeling in the steering, chances are pretty good it isn't a hard part on the suspension. If its not repeatable in the driveway, I would put it on a lift and inspect all underside plastic, we have a lot. When one of those let go, it sounds awful. |
