M57 Boost Gauge
12-24-2011, 09:25 AM | #1 |
355
Rep 18,218
M57 Boost Gauge
Wondering if anybody in here knew if we could run a boost gauge in the 335d to just watch the boost. I still have my RIXster boost gauge from my N54 335i.
Figured it would be fun to watch when, how high, and how long the boost runs while driving around. Any tips or suggestions if there is a way to tap boost pressure on this motor?
12-24-2011, 10:13 AM | #2 | |
356
Rep 2,080
01-03-2012, 01:25 PM | #5 |
Captain Crunch
168
Rep 548
Be nice if we could get this on the dash somehow without having an aux pod/controller.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
01-05-2012, 09:53 AM | #7 |
7
Rep 264
Drives: 335d
did you take it for a drive?
///Andres
09 335d evolve tuned - 327whp / 490wtq -- 13.0@105 95 M3 Turbo - Built 3.0l s52, PTE74GTQ, AEM EMS & CDI 97 M3 NASA TTB build for 2014! |
01-05-2012, 09:55 AM | #8 | |
355
Rep 18,218
02-06-2012, 08:13 PM | #10 |
355
Rep 18,218
02-07-2012, 11:47 AM | #11 |
9
Rep 79
Did you check to see if there were any vacuum lines running directly from the turbo?
I know where we can tap for an electric boost signal, but I guess thats not gonna help anyone. |
02-07-2012, 09:42 PM | #12 |
356
Rep 2,080
Anyone have a bav tech cable. I need to find mine. But I know on the n54 it gave a boost readout. It's on a laptop but still. We can put to rest debates of how much boost the D runs. I shall look for mine.
04-27-2013, 03:09 PM | #13 | |
281
Rep 4,121
2) can you tap fitting 10 in this diagram? http://realoem.com/bmw/showparts.do?...25&hg=11&fg=45 Edit: Fitting 10 is in two places: One on the aft side of the motor tucked back under the lip, and the other, at the front top of the motor. Is either of these places a correct place to tap? Fore Aft I am comparing to the Tap intructions for the N54 (other side of the engine bay)...See PDF picture N54 pdf instructions Last edited by taibanl; 04-27-2013 at 03:29 PM.. |
04-27-2013, 08:13 PM | #15 |
614
Rep 2,410
04-28-2013, 11:50 AM | #16 | |
281
Rep 4,121
Looks like I could use the n55 mode of the p3 gage to get a reading...think it will work? Then again maybe not? bc the 0-5v of the MAP sensor may not be indicative of the the same boost pressure between the n55 and m57? If you could have a look at: http://www.p3cars.com/bmw-install and scroll down to the "Config..." section of the page and read the notes next to "Cal.B" it would be a great help. I know I am asking a lot but I am noob at this stuff. Can you definitively say that neither of the T fittings I took pics of will read boost? Edit: uploading Calibration instructionsP3_Vent_Gauge_Setup_Configuration[1].pdf @ anyone There has got to be a boost indication somewhere besides the large intake pipe??? Last edited by taibanl; 04-28-2013 at 12:15 PM.. |
04-28-2013, 02:34 PM | #17 |
355
Rep 18,218
From my short testing, all of the lines I tested were only vacuum. I assumed they set the M57 up in a similar way to the N55. No boost pressures in the vacuum lines. I ended up selling my gauge.
04-28-2013, 02:50 PM | #18 | ||
281
Rep 4,121
Do you think the MAP 0-5v tap would work as an alternative? Did you try it? Too bad you sold the gauge! |
