Did my water pump just go out???
12-21-2011, 09:45 AM | #1 |
help
103
Rep 111
I got a 06' e90 325i currently at 110k miles. As I was driving it last night, the yellow coolant temp light came on followed immediately by red coolant temp light and it went into limp mode.... I would press the accel but it wouldn't do anything. So i pulled over to check under the bonnet and it seems like there were coolant overflowing from the reservoir (?!). I let it cool some and I pour a bit more coolant/water and started the car the light wasn't on any more so I drove for about another 5 minutes and same thing happened yellow warning light then red. So I just decided to get it towed and it's just sitting in my garage.
So is this the water pump or could it be anything else? And if it is the water pump, do I just replace the water pump or are there some related parts too that I have to replace??? (thermostat?? maybe??) Any help will be greatly appreciated. |
12-21-2011, 09:50 AM | #2 |
11
Rep 339
It is most likely the water pump and/or thermostat. Replace them together. The bad news is the parts are ~$500. The good news is that you can do this job yourself. There are some excellent guides on this forum.
12-21-2011, 09:54 AM | #3 |
253
Rep 7,089
Drives: '06 AW 330xi
If there was fluid leaking out it was probably boiling.....yes your pump is shot.
And +1 for changing both the pump AND the Tstat. |
12-21-2011, 09:56 AM | #4 |
One cam is enough
130
Rep 6,801
Lucky to have made it to the 110k on one pump.
You got limp mode? I didn't get that. Well, maybe I did when it was yellow but that was for only about five seconds, then it went straight to red, where I had absolutely zero power. Gas pedal went to the floor and no response from the engine... |
12-21-2011, 10:02 AM | #5 |
253
Rep 7,089
Why are you guys flooring your engine when you get that light? Thank god our cars don't allow it.....otherwise, you'll need a new engine.
You'd be surprised how fast a coolant system will drop the temp of an engine....likewise, the temp goes up very fast when the coolant system isn't working. |
12-21-2011, 10:03 AM | #6 |
106
Rep 1,428
fyi next time you are driving any car and that has a red temp light on stop the engine immediately. luckily you car is equipped with limp mode that shut it down or you may have caused more damage trying to drive it. these water pumps are much better then they used to be i had a 2000 528i and the water pump went out at 60k, you have a car with 110k dont be surprised if you are going to have to replace other mechanical parts in the near future. i have had 3 modern bmw's in the last ten years for me it is just as expensive to drive a used one as a brand new one.
12-21-2011, 10:07 AM | #7 | |
253
Rep 7,089
Since the E9xs use an electronic pump, they just straight out fail with no warning. And there is no secondary pump which I think BMW should have implemented. It's so dangerous because you have little to no power when the pump fails. What if you're on the left lane of a 4 lane highway? If there is no shoulder on the left, you're screwed and everyone will hate you for blocking the fast lane. |
12-21-2011, 10:09 AM | #8 | |
One cam is enough
130
Rep 6,801
I was trying to keep my speed up to get over on a busy freeway.... As it is, I almost got killed because of it. I had three lanes of traffic (full of Chicago drivers, meaning no one was going to just let me get over, it doesn't happen that easy) to get across starting at 75 MPH and my speed was dropping drastically while everyone else still wanted to continue at a speed no slower than that. Does it make sense now why zero power created a dicey situation? It was a bad time for there to be NO power at all. A little warning would have been nice. Or maybe just enough power to not have to immediately coast to a stop in traffic. I know plenty about what happens if your engine isn't getting proper cooling. And from that knowledge, I also know there's no way I should have 5 seconds of warning before all power is cut altogether. It was pretty shitty IMO. |
12-21-2011, 10:15 AM | #9 | ||
253
Rep 7,089
Stuff like this happens, you can't always get over to the right. That's why I said there should be a secondary pump to at least allow the engine to run at reduced power. But you shouldn't be trying to push your engine to get over to the right when the cooling system is shot. The car was limiting you for a reason. |
12-21-2011, 10:24 AM | #10 | |
One cam is enough
130
Rep 6,801
I'd rather the engine be shot safely on the shoulder of the freeway than be stuck in traffic. Five seconds of warning before complete shutdown is BS. The engine doesn't grenade in that period of time. Something went wrong between the original detection of the pump failure and the cutoff point. Whether that's a design flaw or a fail in the system, I do not know. However, I think normally people have more time than that. That's what it sounds like from what other people have said about their failures on here. I've had plenty of experience with coolant and water pump failures in a lot of cars, and what was staggering to me was the amount of time between the warning and it deciding that it needed to cut the car off right there and then. And the only reason the pedal went to the floor is because I got no response when pushing it gently, so I had to see if there was any power left at all. I think that would have been a pretty normal part of the process for anyone in that situation. Also, the car wasn't just "limiting" me a little bit, it cut me off from power completely. I would have been fine with a minute amount of HP. |
12-21-2011, 10:27 AM | #11 | |
Sensei
52
Rep 1,054
12-21-2011, 10:40 AM | #12 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
I had 65K miles on mine and both repair costed me $1600.
$600 Tstat & $1K for the pump.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
12-21-2011, 10:41 AM | #13 | |
253
Rep 7,089
Most of the failures have no warning. I've read on multiple accounts that people were angered by the fact that pump just failed resulting in no power and they were in dangerous situations from it. I'm dreading the day this happens to me....I'm at 73k. *Crossing fingers* |
12-21-2011, 10:49 AM | #14 | |
One cam is enough
130
Rep 6,801
I was not in the left lane, I was in lane 4 of 5 with no shoulder on the left (literally less than a foot). And it's a terrible spot where you usually have drivers who end up in secondary and tertiary collisions when something like that happens. I'm just glad I was still in an area where there was a shoulder to the right, many freeways in Chicago have a lot of places where you don't have a shoulder on either side. In any case, no option was a good option at that point. I guess that's what infuriated me. I had dealt with sudden limp mode and HPFP problems, which weren't a big deal. However, I believe there has to be a better option for how the car deals with a water pump failure. Immediate and total loss of power doesn't seem like a good idea to me, although I can see why it makes sense to an engineer whose job is to ensure that the engine stays intact. SA said the pumps commonly start going out around 60k (although I'm going to use the word "commonly" very loosely as many have way more mileage than that and haven't had the problem). I think mine was at 54k or so. Given the relative low cost of a replacement, I'd highly recommend anyone over 60k get theirs replaced, but it's not inevitably going to fail and try to kill everyone out there. I'm not trying to plant panic or seeds of doom in the community about the water pump, but it's a pretty common failure, and when it fails it can be a very harrowing experience. I'd take all five of my HPFP failures all over again before I'd take just one more water pump failure. |
12-21-2011, 10:55 AM | #15 | |
253
Rep 7,089
Apparently there are shadow faults that will store in the DME indicating a reduced flow rate. But what good does that do for the average consumer? I scan my car every 2 weeks to check for codes and reset adaptations. But not everyone has access to a scan tool and even if they do, I don't think people scan their car on a regular basis like I do. Bad move on BMW's behalf. |
12-21-2011, 11:09 AM | #16 |
Railside Performance
48
Rep 331
Drives: E92 M3 R8 V10 Q5
Garage List 2010 Ducati Streetf ... [7.00]
2017 Q5 [0.00] 2017 BMW R NineT Racer [5.00] 2010 Audi R8 V10 Ma ... [0.00] 2008 M3 [10.00] |
The first sign of pump failure is usually a loss of heat from your vents, followed by a yellow warning light and quickly followed by a red light and having the car go into limp mode. There is a 100% mark-up on these pumps so bargain with your sa or parts guy and installation is just an hour. You can do it yourself, but is a pain in the ass and the bolts are hard to reach when laying on the driveway. The pumps are electric and are prone to failure. Good luck!
12-21-2011, 11:13 AM | #17 | |
Higher than you
8
Rep 294
Water pumps are maintenance items. If BMW doesn't recommend a specific service interval, then use the anecdotal evidence from the forums to make your own. I'd rather give up 10-20k miles by changing early than risk being stranded by a failure, or possibly overheating the engine and doing even more damage...
Current: '15 M235iX | '15 Macan S | '00 Honda S2000 Notable Previous: '12 E92 335is | '10 STi | '88 E30 325iX |
12-21-2011, 11:13 AM | #18 |
One cam is enough
130
Rep 6,801
12-21-2011, 11:15 AM | #19 | |
253
Rep 7,089
I'm just waiting for those shadow faults to pop up. Hopefully they do! But $700 for parts is an expensive maintenance item! Also, OP, you might also want to swap your oil filter housing gasket. That is known to chunk off into the coolant system and damage the impeller in the pump....this is problem with most BMW engines. |
12-21-2011, 11:29 AM | #20 |
Higher than you
8
Rep 294
BMW WPs have always been pricey. I recall my father spending $200 on a pump for his 2002tii back in the '80s.
I'm interested to see how the shadow codes work out. Unfortunately, to know if they really work, you'll have to detect the code and then let the pump fail. Kinda like HAL in 2001: A Space Odyssey and the com antenna.
12-21-2011, 11:47 AM | #21 | |
964
Rep 3,854
Drives: 330i, 135i
12-21-2011, 11:51 AM | #22 |
424
Rep 1,325
Just had that happen to me on Monday. Yellow coolant light and then red coolant light. No power. Pulled over and then had it towed to the dealer. It was indeed the water pump. Replaced that and the thermostat.
All good now.
