idle pulley&tensioner change 325i
12-18-2011, 05:00 PM | #1 |
201
Rep 1,714
Drives: 2011 335i
Hey guys i was wondering i have to replace my tensioner and idle pulley. Im not paying the stealership to get this changed. I like to get my hands dirty. Just need some word of advice and how to replace thease parts on our cars. I dont want to break anything. Thank you ahead for all your help
12-18-2011, 05:07 PM | #2 |
74
Rep 1,035
You just need to remove the belt and a few Torx bits to swap it out. Its relatively simple. Its a little tight with the fan depending on what length your Torx bits are, it may be easier for you to remove the fan, which is simple as well to gain access. Other then that its very straight forward. Let me know if you want to come down to my shop in Wallingford, I can take care of it for you.
12-18-2011, 05:09 PM | #3 | |
201
Rep 1,714
Drives: 2011 335i
12-18-2011, 05:55 PM | #5 | |
74
Rep 1,035
I wouldnt say never. There are a few common problems over time. The bearing in the pulley can seize up. Pulley squeaks. Have seen on many occassions the tensioner start to bend a little causing the belt to be misaligned. Also have seen the tensioner get weak causing the belt to "snap" while starting causing an annoying rattling noise. |
12-18-2011, 07:02 PM | #6 |
201
Rep 1,714
Drives: 2011 335i
. I'm getting a noise not sure if it's only the belt. The sound is only on cold start and goes away when the car is warm. Sounds like sht sht sht sht sht. Just need to make sure it's nothing else otherwise wont have to change the pulley nor the tensioner just the belt. I have 73,000 miles on the car belt was never changed.
12-18-2011, 09:36 PM | #7 |
165
Rep 7,433
Well I had to replace mine when the bolts holding the tensioner sheared off and the belt was barely being held in by one notch on the belt.
Good thing I happened to notice it.
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
12-18-2011, 10:36 PM | #8 |
201
Rep 1,714
Drives: 2011 335i
12-18-2011, 10:37 PM | #9 |
201
Rep 1,714
Drives: 2011 335i
anyone know how to remove the tensioner. and idle pulley. im going to change everything belt, tensioner, and idle pulley
12-18-2011, 10:52 PM | #10 |
201
Rep 1,714
Drives: 2011 335i
Ok I Found A Great Picture Of The N52 Engine And I Market The Tensioner And Idle Pulley. Can Somone Please Confirm If This Is Correct. Thanks.
SORRY FOR THE HUGE PICTURE |
12-19-2011, 02:54 PM | #11 |
201
Rep 1,714
Drives: 2011 335i
Bump
12-19-2011, 03:10 PM | #12 |
Grozniy
177
Rep 2,602
looks right
before removing the belt, draw the diagram I was lazy and didnt take pictures and spent 20 minutes figuring out how the belt goes on haha in order to remove the idler pulley, remove the black cover first youll see a bolt that holds it in place make sure you use torque wrench and proper specs otherwise you may have a vibration
-fatman
12-19-2011, 03:40 PM | #13 | |
201
Rep 1,714
Drives: 2011 335i
12-19-2011, 04:00 PM | #14 |
Some dude
92
Rep 1,780
The tensioner bolt (Torx head) is a one-time use aluminum bolt, torque to 18 lb-ft then 90 degrees. You must replace it. The deflection pulley on the side of the alternator is just 30 lb-ft torque, no need to replace that bolt. Very easy DIY job. You will also need a T60 torx bit to unload the belt tension.
RRT
E92 335i/6MT with stuff and things |
12-19-2011, 04:15 PM | #15 | |
201
Rep 1,714
Drives: 2011 335i
12-21-2011, 06:47 PM | #16 |
201
Rep 1,714
Drives: 2011 335i
Just an update. The job was successfully for a first time noob. I changed the idle pulley, the tensioner and the serpentine belt. Also I replaced my vanos solenoids just for good measure. All I can say is I got my torque back and the car runs like I just took it off the lot. I want to thank all of you that helped me and if anyone needs pointers since I've done this please let me know.
12-22-2011, 10:11 AM | #18 |
50
Rep 825
Drives: a car.
whoa, nice work fanatic!
12-22-2011, 12:01 PM | #19 |
Rep 142
Mine is squeaking like crazy. I hit it with some wd40 and it stops but only for a second. Hit with some silicone spray and got the same thing. I guess mine is bad as well. Do you have the part numbers minus the vanos solenoids?
12-22-2011, 03:46 PM | #20 |
201
Rep 1,714
Drives: 2011 335i
I had some extra money around so I was like why not and just changed them with everything else for good measure. The car runs so much smoother and the torque at low end is back after changing them.
12-22-2011, 03:48 PM | #21 |
201
Rep 1,714
Drives: 2011 335i
I will get the part numbers for you ASAP. My idle pulley and tensioner where completely shot. I suggest you change it. So easy a caveman can do it.
12-22-2011, 04:24 PM | #22 |
Rep 142
Id appreciate it. Im a shade tree mechanic at best. If you could give me a brief walk thru that would be great too. Ill do both pulleys and the belt as well. THX.
