2010 2011 BMW 5 Series Forum F10 "correct factor", "change factor" in hidden menu, what is it? |
12-06-2011, 07:17 AM | #1 |
19
Rep 85
Hello, I found this option in hidden menu, what is it?
How to get to hidden menu? 1. Hold down the odometer reset button and turn the ignition on by pushing start/stop button. 2. Release the odometer reset button, and you should see a menu of 4 items on the dashboard. From here on, use the odo-reset button to advance to the next entry through a short press, and to select through a long press. 3. Choose the one that says Unlock through the above, which will take you to a passkey screen. Your passkey is the sum of the last 5 digits of your VIN. Increment the two-digit number until you get to it, and with the long press of the odo button, select it. Maybe it should be in "Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications ". But now, everyone knows how to get to hidden menu |
12-06-2011, 07:31 AM | #2 |
256
Rep 4,721
It's to correct any fuel consumption issue spec. to the engine.
If you google ... correct + change factor + BMW ... you will get a bunch of hits that explains it. I would not touch or play with it. |
12-06-2011, 01:55 PM | #4 |
116
Rep 1,346
Drives: 2011 E92 335 M-Sport
play with it, change as many settings as you can, I want to see hilarity ensue.
12-16-2011, 12:59 AM | #7 |
87
Rep 937
After my initial correction, my last tank nearly matched perfectly (28.2 MPG calculated, 28.5 shown on the trip computer).
03-03-2012, 04:21 AM | #8 |
Rep 25
HELP!
I may have accidently "fat fingered" the fuel consumption correction factor on ky 2011 335d, and now the fuel economy registered on both avg consumption and the instant log gauge seem to be reading terribly low... Can someone please provide what their 335d correction factor is, so I can at least have a baseline to reset mine to? Any help would be greatly appreciated!
03-07-2012, 03:11 PM | #10 |
Rep 25
Thanks SNJ! I reset it to 1000, and it seems to be reading a lot more accurately. I'll adjust from here, after I have a chance to hand calculate.
