12-03-2011, 12:24 PM | #1 |
137
Rep 718
Drives: N/A
Urgent Help!!! 1M with 18" winter tire with VMR VB3
Hi,
I just started to change my 1M with winter tire with 18" VMR VB3. After I put on the front, the brake is really really close to the wheel. Is that ok? should I be worry about it?
2021 F87 HS M2C
2018 F80 SO M3 (SOLD) 2016 F80 AY M3 (SOLD) 2014 F10 M5 LCI (SOLD) 2011 VO 1M (SOLD) |
12-03-2011, 12:30 PM | #2 |
137
Rep 718
Drives: N/A
this is the pic for 18"
2021 F87 HS M2C
12-03-2011, 12:34 PM | #4 |
137
Rep 718
Drives: N/A
the spacers wont help with the brake clearance right?
2021 F87 HS M2C
12-03-2011, 01:08 PM | #8 |
137
Rep 718
Drives: N/A
i thought spacer is for push the wheel outward from the car....
2021 F87 HS M2C
12-03-2011, 01:10 PM | #9 |
137
Rep 718
Drives: N/A
Tires: Dunlop 3D Winter Tires Front: 235/40/18 Rear: 255/40/18 18"x8.5" +20mm VB3 Style Wheels 18"x9.5" +22mm VB3 Style Wheels
2021 F87 HS M2C
12-03-2011, 01:14 PM | #10 |
137
Rep 718
Drives: N/A
I think I know why you guys suggest the spacer.
My problem is the gap between the brake and the inside of the wheel is so so little. between the caliper and the edge of the inner rim
2021 F87 HS M2C
12-03-2011, 02:53 PM | #12 |
9
Rep 270
Technically if it spins you should be ok. The spacer is going to push the wheel out and give you more clearance in the barrel of the rim.
12-04-2011, 06:44 PM | #13 |
40
Rep 1,058
A spacer will make no difference, the clearance is reduced because the wheel radius is reduced when you went down to an 18" rim, my winters are very close too, I'm running 18 x 9.5 VMR 710's. My clearance from brake to wheel is the same as yours, I put the wheels on today and have no issues.
The faster you go, the better it feels
12-04-2011, 06:57 PM | #14 | |
183
Rep 3,939
If you installed the wheels all the way, tightened the lugs, and spun them by hand without clearance issues, you should be good to go. |
12-05-2011, 09:03 AM | #15 |
137
Rep 718
Drives: N/A
Thanks ESC OFF,
that's what I want to see.
2021 F87 HS M2C
12-05-2011, 06:49 PM | #17 |
83
Rep 562
Drives: 2011 1M VO
Not close with Sport Edition 18x8 A7.
12-05-2011, 11:21 PM | #18 |
40
Rep 1,058
When you -1" on rim size your calipers will be very close, you are basically moving the wheel 1/2" closer to the caliper, nothing to worry about with a decent quality wheel. If you buy really cheap wheels you could risk brake/wheel contact if the wheels get out of round.
