12-02-2011, 09:09 AM | #1 |
2866
Rep 11,374
E82 1M Exhaust system database
The 1M is still a fairly new car, and as always we want to do our best to ensure our clients are well informed prior to making any purchasing decisions. We took this photo of an OE BMW 1M exhaust system to showcase each component of the exhaust system and give 1M fans an idea of exactly what they are changing or replacing when purchasing a performance exhaust system.
Any vendors or 1M owners, feel free to post photos of your performance exhausts for comparison!
12-02-2011, 06:28 PM | #5 |
1M Owner
36
Rep 239
Nate, very helpful diagram! I was searching last weekend for an image like this and could not find anything. I was under the car a few days ago trying to figure out where the hangers and connectors were, and this makes it very clear.
12-03-2011, 12:30 PM | #6 |
436
Rep 2,373
Many people are asking about 1M Akrapovic Exhaust system so here it is:
Akrapovic Evolution System Connecting pipes and Down Pipes Bypass Valve - Part of the Wireless Kit Rear Muffler Titanium Tips Wireless Kit Aleks. |
12-03-2011, 02:01 PM | #7 |
224
Rep 3,094
So the bypass valve allows two pipes to bypass he muffler completely? This means without the wireless kit you are only really exhausting through 2 pipes? Is that correct?
12-03-2011, 02:09 PM | #8 |
2866
Rep 11,374
Option 1. Full downpipe back Eisenmann Race performance
Option 2. Rear bolt-on section (bolt-on to OEM center pipe) 4x83mm Quad Round tips Made in Germany No cutting needed http://www.m3post.com/forums/showthr...Eisenmann+tour Eisenmann E82 1M "Slip-on" rear section-
12-03-2011, 04:49 PM | #9 |
10
Rep 233
Without the wireless kit the exhaust valves on the two outer pipes are shut but someone said with some work they can be removed. I used to have the capristo exhaust on my RS 4 and it open/closed valves with a remote. it is a nice feature to have especially if you live/work in noise sensitive areas.
12-05-2011, 10:19 AM | #16 |
5365
Rep 3,789
Supersprint/Evolve 1M Exhaust System
Here is the Supersprint System which can be specced with the SS TUV approved (pending) rear exhaust or the "Race" Evolve rear exhaust.
Downpipes - Decat Front Pipes with 100 Cell Cats Front Pipes with Cat Delete Resonated Centre Pipe Non Resonated Centre Pipe TUV Rear Exhaust - can be fitted as bolt on without full system Evolve Race Exhaust - can be fitted as bolt on without full system Dyno Graph - Full System, 100 Cell Cats with Race Rear Exhaust. +15.4 HP and 18.9 Nm Torque. |
12-05-2011, 04:58 PM | #17 |
2866
Rep 11,374
Milltek E82 1M (Downpipe back exhaust)
Pipe Diameter: 3.00" (76.20mm) 4x80mm Quad tips Made in England
12-05-2011, 05:20 PM | #18 |
2866
Rep 11,374
Akrapovic Slip-on exhaust
Akrapovic Slip-on (100% Bolts on to OEM flange)
4x90mm Carbon or Titanium tips Made in Slovenia • Plus 5 HP (at 5,670 rpm) • Plus 5 Nm / 4 lbs-ft of torque (at 3,100 rpm) • 1 kg / 3 lbs. lighter than stock Install PDF- http://www.akrapovic.com/typo3conf/e..._evo_optdp.pdf 4x90mm Titanium tips- 4x90mm Carbon tips- Wireless kit- New photos - Slip-on with Titanium tips Videos-
12-05-2011, 05:40 PM | #19 | |
2866
Rep 11,374
OEM downpipes vs. Akrapovic
OEM dp's vs. Akrapovic by Aleks
Akrapovic downpipe photos-
12-06-2011, 09:26 AM | #20 |
2866
Rep 11,374
Revozport "Raze" full downpipe back
Full Titanium Made in China
12-06-2011, 09:38 AM | #21 |
2866
Rep 11,374
Lightweight Titanauspuffanlagen E82 1M
Full downpipe and rear section (bolt-on flange) Made in Germany http://www.lightweight-titanauspuffa...ent/bmw_m1.htm Rear section with bolt-on flange Full downpipe back-
12-08-2011, 10:01 AM | #22 |
2866
Rep 11,374
AC Schnitzer E82 1M
E82 1M AC Schnitzer
Made in Austria Rear section "cut and clamp"
