BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > MAF sensor
      11-30-2011, 09:52 PM   #1
Julesandtrish
Julesandtrish's Avatar
27
Drives: 335d
2010 BMW 335D  [10.00]
MAF sensor
Has anyone tried cleaning the MAF sensor yet? (with cfc sensor cleaner) I did this on my e39 M5 every 20K and it seemed to help the responsiveness of the engine. Or Is this a mute point with the D?
Enjoy what you drive.
      12-01-2011, 08:37 AM   #2
neovb
9
Drives: 2011 BMW 335d
Have you checked to see if your sensor is dirty? After about 10k miles, mine still looks good as new.
I'd say there's probably no harm in cleaning it either way.
      12-05-2011, 08:33 PM   #3
Julesandtrish
27
Drives: 335d
Yeah. I've got 43k on the clock now. I think I'll clean it this weekend. I'll post afterwards if I notice a difference.
      01-16-2012, 01:44 PM   #4
NJ 1161
NJ 1161's Avatar
75
Drives: 335D M3
What does a clean involve and what every day substances can you use to clean??
What do you look for when checking dirtyness of maf??
      01-31-2012, 02:54 PM   #5
NJ 1161
NJ 1161's Avatar
75
Drives: 335D M3
Anyone done this?? Is it worthwhile?
      01-31-2012, 10:26 PM   #6
Julesandtrish
27
Drives: 335d
Have not got around to doing this yet. Been busy. I will try in the near future and post results.
      02-01-2012, 08:48 PM   #7
Quasimodem
Quasimodem's Avatar
Drives: 335d
2009 335d US  [0.00]
Not a mute point, unless you can't hear it. Maybe a moot point though....
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
      02-02-2012, 07:44 PM   #8
Julesandtrish
27
Drives: 335d
Don't you mean a soot point? Ha ha......
      02-03-2012, 06:42 AM   #9
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Moot point. Not enough on the road to know whether its a common malady @70k miles or more.
      02-04-2012, 02:48 PM   #10
Quasimodem
Quasimodem's Avatar
Drives: 335d
2009 335d US  [0.00]
I apologize if my response wasn't sootable.
      04-20-2012, 11:22 AM   #11
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2021 M5 Competition  [0.00]
2016 BMW 550i  [0.00]
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
Someone post up a pic of the MAF and where it's at. Getting an Air Mass Sensor SES lately, and I need to see if it's just dirty, or if I need to take the car in (and, if anyone knows, is the MAF covered under the emissions warranty?).
Current: '21 M5C, '15 X6 50i Previous: '18 M550i, '16 550i, '11 335is, '09 E93 M3 DCT, '10 E90 335d, '07 E90 328i
      04-21-2012, 08:37 AM   #12
Coolieman1220
Trinidad_and_tobago
73
Drives: 2010 335d
I believe it should be. if it throws an SES light, that light is emissions related.
      06-19-2013, 04:13 PM   #13
TDIwyse
614
Drives: 2011 335d
So, this week I started getting a P0101 MAF code. Only at higher engine loads. Using the Torque App I could quantify a ~10-15 hp loss compared to "normal" and lower peak boost readings (it uses the MAF readings to calculate boost). So... something strange was afoot.
Removed the MAF and noticed a small piece of cottonwood pollen clinging to the very middle section of the mesh screen on the air box side that protects the hot film element from debris. I replaced the air filter earlier this spring and perhaps that contaminant found its way in there during the process? Not sure. I removed that from the screen, and since it was already detached, decided to "clean" the sensor with CRC fluid. Sprayed it and the electrical connector, let dry, re-assembled.
Cleared code and road tested. No more codes at full fueling and the lost power was back.
Since I did two things at once I'm not sure which "fixed" the issue. Question for those with MAF experience: Could the pollen blockage directly in front of the hot film element cause enough turbulence/blockage to the air stream that the MAF reading at higher air utilization was out of whack? Or is it more likely that the CRC cleaning was the more likely cause for the improvement?
      06-19-2013, 04:29 PM   #14
FormerRotor
FormerRotor's Avatar
95
Drives: 2011 335d, M-Sport
@TDIwyse , the other reason for the mesh screen is to more evenly distribute the airflow over the film. A decent sized bit of anything sitting there-on could certainly cause enough turbulence to yeild unstable readings. This coupled with a slightly dirty sensor was your likely culprit. Like you said, though...no way to conclusively determine how much of which was the cause.
My Picture Threads (Oldest to Newest): 1 2 3
Join BMW CCA! (Use my link and I get credit )
      06-19-2013, 04:30 PM   #15
335dFan
Jumping Jack Flash
335dFan's Avatar
Drives: 2021 X3 M40i
Anybody have any pics showing where said MAF is?
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d
Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al.
      06-19-2013, 04:39 PM   #16
Ron1n
Speed Demon
Ron1n's Avatar
Drives: 2021 M5C
2011 335is  [0.00]
2009 E93 M3  [10.00]
2010 335d  [9.50]
It's just to the right of where the air filter is, into the center of the pipe that funnels the air from the intake to the turbos/engine.
      06-19-2013, 05:15 PM   #17
FormerRotor
95
@335dFan
http://parts.bmwofsouthatlanta.com/s...hString=filter (part#1)
      06-19-2013, 05:20 PM   #18
TDIwyse
614
Drives: 2011 335d
Thanks for the responses guys. If nothing else, it's something for the forum members to look at if they get a similar code ...
      06-19-2013, 10:06 PM   #19
atam12
Drives: 2011 335d
Does anyone know what is needed to remove the MAF. Special tools or what?
      06-20-2013, 06:30 AM   #20
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Uh..no.
It's called wrench boredom.
      06-20-2013, 07:03 AM   #21
TDIwyse
614
Drives: 2011 335d
There's 2 Torx bolts (T-30 if my memory is correct) that holds the MAF housing to the air box (and there's a large, thick rubber o-ring at the interface as well) and then a standard metric bolt worm/clamp on the other end of the housing/air duct interface.
      06-20-2013, 07:43 AM   #22
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
It is easy to remove, another thing if your running K&N be carefull oil doesnot run thru the piping and gets your MAF otherwise it will render it w/o warranty this happened to me with my 02 MCS I had a K&N look alike and iol messed up my MAF
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
