2010 2011 BMW 5 Series Forum F10 Detail addict-Platnium Addict, 2009 Camaro |
11-29-2011, 12:26 PM | #1 |
300
Rep 4,444
We hope everyone's car is looking so great in the WINTER! Roll up your sleeves before the weather gets really bad, it will protect your car for awhile!
2009 Chevy Camaro This car is only about 1.5 months old. The dealership did a very hacked job on it and filled EVERYTHING. It looked nice, but once we stripped everything, it was halogram EVERYWHERE. Although it's new, it has some very sever RDS and minor swirl marks. The entire process took about 20 hours or so... Wash Camspray Foam Gun Detail Addict Water Softening System Detail Addict Car Soap Detail Addict Grit Guard Detail Addict Wash Mitt Detail Addict Waffle Weave Drying MF Detail Addict Engine+Wheel Cleaner Porter Cable 7424XP Makita 9227C Detail Addict Backing Plate Detail Addict CCS Pad Set Detail Addict Medium Grade Clay Bar Detail Addict Detail Spray (lube) Menzerna Power Gloss (S34A) Menzerna Super Intensive Polish Menzerna Super Finish Polish Menzerna Final Polish Detail Addict Sealant Wax Miscellaneous Detail Addict Glass Cleaner Detail Addict Glass Towe Detail Addict Rub&Shine Detail Addict Dressing Sponge Detail Addict Polishing MF Detail Addict Detailing/Polishing MF Sorry, it was very cloudy so no good pictures of "before"at outdoor that we can share with everyone... , but u can still the swirl marks in some of the pictures. We start with the wheels and tires using P21 Wheel Cleaner and let it soak a bit Off with a hand brush to get the spokes Then with ACE PowerStick to get to the inside of the wheels Recommended Products Pressure wash off everything Including the wheel wells Then we start with the body to get the 'big dirt' off the car... Hit the tires again as we rinse the body Then off to our Camspray Foamer You can never clean the wheels/tires enough! Then off to two buckets hand wash with fresh MF Recommended Products Then glide the water off of the car Rinse down the wheels of course Look at this! Brand new car! This is from just the hood too! Air dry all the gaps and surfaces as much as we can After air dry, we use Waffle MF to blot dry Look closely, lot of RDS! We then took a paint meter to check the thickness and it was about ~145-185 micron all around. Plenty of paints on this car for correction! and swirl marks Still trying to perfect close up shots... But yeah, lot of swirls... Here are bunch of 50/50 Some indoor finishing shots The sun finally came out the next day for us to take some outside pictures! Best wishes! |
