Coby Wheel
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > SPONSORS Classifieds/Groupbuys/Specials Area > Turbo Engine / Drivetrain / Exhaust Parts > >>HP Autowerks<< Extreme Turbo Systems Intercooler for BMW 335
      11-29-2011, 02:09 AM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
The ETS intercooler Kit Features
-Full Intercooler Kit- Includes Intercooler, Charge Pipe, Couplers,Clamps
-Direct Bolt on with absolutely no cutting
-Replaces Restrictive Stock Piping
-Max HP Gains of 21.05hp
-Over 60deg Lower Temps
-No Heat Soak after a Pull
-Reduces Knock
-Durable Stainless Steel Piping
-4 Ply Silicone Couplers
-Breeze Premium T-Bolt Clamps
-Stock system has an accordion hose at the inlet. This hose will create turbulence because of the ribbed design.
-ETS Solution- Extend the inlet tube to reach the stock turbo outlet pipe and use a straight, smooth silicone coupler.
-90deg bend at the intercooler outlet is restrictive to flow.
-ETS Solution- Split the sharp 90deg bend up into a 60deg and a 30deg bend. This still makes a 90deg turn, but is not as sharp as the stock 90deg hose. This allows for better airflow post intercooler.
-Plastic Pipe has restrictive dimples protruding into the airstream.
-ETS Solution- Use a Stainless Steel mandrel bent pipe that is uniform inner diameter throughout it's length improves flow as well.
Price is $770 + shipping.
Multiple options for intercooler anodizing, core thickness and piping color.
http://hpashop.com/Extreme-Turbo-Sys...er-e9x-335.htm
      04-17-2013, 11:29 PM   #2
HP Autosport
Drives: F80 M3
Bump!
