Debating on modding my 335i
11-24-2011, 09:51 AM | #1 |
Rep 49
I've left my 335i completely stock for about a year but since I have a ms3 I have some extra parts that I could make use of namely a standback, ewg and dashhawk. If I chose to mod the car I'd convert over to e85, raise boost, and increase timing. Do you guys have any issues with load induced fuel cuts, or boost cuts? I'd also add the ewg to the stock DP so i could relieve back pressure without throwing CEL's all the time.
11-24-2011, 09:59 AM | #2 |
161
Rep 7,377
good luck...
11-24-2011, 03:47 PM | #3 | |
158
Rep 1,288
Drives: 2014 435iX, FBO
I have no idea what you are taking about I will say MOD IT
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
11-24-2011, 04:47 PM | #5 | |
7
Rep 121
i know you got a beast of an ms3. but from what i read here on the forums everything is plug an play or have the cars professionally tuned. I dont think i've seen any personal owner try to tune their own bmw as you would with the Ms3. also, from what i read bmw is able to tell if you have tuned the computer but it only applies to some models |
11-24-2011, 05:52 PM | #7 |
68
Rep 511
11-24-2011, 05:54 PM | #8 |
406
Rep 3,583
Drives: 2017 M3
2017 F80 YMB, ZCP, ZEC, ZLP, DCT. Production Date: 7/15/16
11-24-2011, 06:14 PM | #9 | |
Some dude
92
Rep 1,780
I'm always dumbfounded when people think a $500-1000 ECU can run an engine even remotely as good as the incredibly powerful modern OEM ECUs can. Some garage electronics guys are smarter then Siemens? Bosch? Magnetti Marelli? Denso? You get the idea... You want to tune an N54? Get a piggyback or a Cobb AP and go to town. Replacing the factory Siemens MSD80/81 is a losing proposition. Edit: let me be clear, I'm not trying to shit on your ideas. I'm just saying that yes, a megasquirt can run an engine, but nothing even close to what the factory ECU is capable of.
RRT
E92 335i/6MT with stuff and things Last edited by JamesM3M5; 11-24-2011 at 06:31 PM.. |
11-24-2011, 09:52 PM | #11 |
Joint Chiefs of Staff
4920
Rep 115,999
Just get a tune (JB4, Proceed or COBB) and a DCI and a set of cat less downpipes and you are guaranteed to have a huge grin on your face every time you hit the gas pedal
Mike |
11-24-2011, 10:12 PM | #13 | |
177
Rep 6,631
OP - Your MS3 CP-E standback won't work on the N54. I'd say sell your MS3 mods on your forum of choice, get an N54-specific tune (I prefer Cobb), and the appropriate bolt-on modifications. You can't convert the N54 to E85, but you can run E85 at a 2:1 pump/ethanol ratio and get away with it. Not recommended long-term though. Methanol injection seems to be the tried and true power adder over E85 on this platform though. After extensive logging with proper parameters, I can't say i'm a full fan of methanol any longer.
E90 LCI N54 6AT
11-24-2011, 10:14 PM | #15 | |
68
Rep 511
11-24-2011, 10:28 PM | #17 |
177
Rep 6,631
Log timing on all six cylinders and knock volt on the cobb AP on meth when the race map comes out and you'll see.
Mostly caused by improper distribution is my guess. Honestly, I don't even believe PWM-based meth kits like the HFS-3 would resolve this. The bottleneck is the fact even properly atomized air/methanol mix won't be evenly distributed across all six cylinders, which is more of an issue than unevenly distributed charge air. The problem is if you inject two nozzles at the same injection point (the most common point is the elbow connecting the FMIC outlet to the charge pipe) you lose the benefit of proper atomization by cross spraying two nozzles at the same point. I don't plan on giving up methanol anytime soon actually Just some discussion and observations. But I am in search of an alternative, and E85 seems to be the next step... at least for testing purposes.
E90 LCI N54 6AT
11-24-2011, 11:49 PM | #18 | |
7
Rep 121
dashhawk is what they use to make power, as well as upgrading EWG=external wastegate. they also use the Cobb AP to tune timing using e85, AFR, fueling, boost and much more. |
11-25-2011, 12:26 AM | #19 |
60
Rep 2,334
I see, thanks. Im not familiar with that car at all, but good to know.
11-25-2011, 03:18 AM | #20 | |
161
Rep 7,377
11-25-2011, 03:36 AM | #21 | |
278
Rep 5,062
Drives: Black e92 335i
With all the bannings lately the pool of knowledge on this forum is suffering and the number of quality posts are dramatically declining. Keep it up man
JB4 / OSS Angel Eyes / Downpipes / F1-Racewerks FMIC / Custom Meth Kit / BMS DCI / ER Chargepipe / HKS BOV / BMS Meth Elbow / BMW Performance Exhaust / Carbon Fiber Inlay Quad Tips / 19" Miro 111 / Front Aero Lip / M3 Sides / VRS CSL Trunk / Mtech Rear / DD CF Quad Finned Diffuser / LCI Tails / BBK / Smoked Reflectors / F1 Euphoria LED Interior / License LED's / GT 5000k Corners / 5000k HID Fogs / Air Scoops / LED Turn Signals / FK Silverline Coilovers / HPA endlinks / Vibrant Resonators / Osram CBI 5000k D1S
11-25-2011, 03:44 AM | #22 |
278
Rep 5,062
It's time for a direct port meth setup
Somebody fabbbb it up.
