      11-23-2011, 11:55 AM   #1
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
iND | Challenge Rear Toe Arms
The E9x M3 and E82 1M chassis has limited rear toe adjustment from the factory, and an aggressively lowered car will lack sufficient adjustment range to bring the toe within appropriate spec. Challenge's rear toe arms not only give a wider range of toe adjustment, but also include an eccentric bolt eliminator to fix the normal eccentric adjuster, allowing for more consistent alignment settings.
Challenge toe arms are constructed from 6061 aluminum, use high quality rod ends, and include tapered adjustment areas for the lowest possible stress riser along with rubber seals to for the longest possible rod end service life
Pricing:
Challenge Rear Toe Arms - $325.00
Optional All-Weather Heavy Duty Boot Set (+$40)
Shipping:
Within the lower 48 states - $15.00
Canada - $25.00
For extended delivery point please contact a iND representative
Phone: 866.963.4520 (Local 847.963.4520)
Email: info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
Search this Thread:
Advanced Search
