Rims damaged during tire change
11-22-2011, 09:03 PM | #1 |
Rep 61
A quick question for the more mechanically inclined members who has changed tires themselves in the past, or know exactly how the tires are changed.
Is it impossible to avoid damage(s) on the rims when switching out the factory all season run-flats tires? A little bit of background, changed out the factory all season run-flats on my 3 series last Saturday with a set of winter tires. Noticed some small scratches on the face of the rims, and significant scratches along the outer circumference of the rims, where the metal meets the rubber (or very close to it at least). Shop tech acknowledged the scratches, but said damages are unavoidable since the run-flats are stiff and hard to get (pry?) off the rims. Will be talking to shop manager in the next couple of days to sort this out. What do you guys think? Do I have a case for compensation? Thanks in advance for the info. Edit: links to pictures View post on imgur.com View post on imgur.com View post on imgur.com View post on imgur.com Last edited by BlueElectrin; 11-22-2011 at 09:29 PM.. |
11-22-2011, 09:34 PM | #4 |
74
Rep 1,309
IDK how Costco tire centers are, but I'm sure there were a lot more reputable shops in your area? They should have equipment where you don't need to "pry" anything. FWIW, I just had my runflats changed the other month, and no damage was done to my 189s. Also, if he acknowledged the damage was done by him and his staff, 100% compensation.
11-22-2011, 09:36 PM | #5 | |
Rep 61
Also, the tire techs I chatted with did not use the word "pry", it's a guess on my part. Lesson learned! |
11-22-2011, 09:37 PM | #6 |
74
Rep 1,309
Lesson learned indeed! Always search your regional sub-forum for recommendations on any type of shops. If he acknowledged the damage was done by him and his staff, 100% compensation.
11-22-2011, 09:39 PM | #7 |
Rep 61
Will be pushing for the 100% compensation, will probably phone some indy shop in town tomorrow and get a second opinion on what they think of this matter.
11-22-2011, 09:41 PM | #8 |
74
Rep 1,309
You should definitely be able to get fully compensated. I'm assuming he didn't tell you before doing so, "Oh by the way, we can't avoid it and we'll probably damage your wheels since they're runflats."
11-22-2011, 10:56 PM | #9 |
TWNEGOS
11
Rep 107
Runflat sidewalls are definitely ridiculously stiff and why majority of shops charge more to mount runflats.
But with the proper machine it shouldn't scratch at all. This is what our shop has. Doesn't touch the wheel at all and basically mounts the tire for the tech. It's done a 30" wheel and threw it on like it was 18" tire http://www.hunter.com/tirechanger/auto34/index.cfm Most likely my guess is Costco has something like this below. This is what we use to have. This has several arms that can touch the wheel. And you can see the pry bars pictured as well to help with removing the tire. It also comes with a low profile tire tool. While on some lower profile tires with this machine it would require the bar, if used properly you still won't scratch the wheels. Costco should still take care of the scratches for you!! |
11-22-2011, 10:56 PM | #10 |
9
Rep 338
I had the same thing happen to me by an Indy shop when I had my winter tires put on for the first time. 1. You should be fully reimbursed for repair. If damage was unavoidable using their equipment, they should have informed you of this beforehand so you could make an informed decision. 2. Tire mounting is the one thing on my car that I will only get done at the dealer - they have the right gear and I'm way to anal to deal with unnecessary scratches. 3. Consider getting a set of winter wheels.
11-22-2011, 11:33 PM | #11 |
Rep 61
Thanks for all the info guys, so I will be using the two following train of thought when speaking with Costco's tire shop manager.
1. Tire changing with proper technique/machinery will not result in any kind of damage to the rims. 2. Costco tire shop did not perform their due-diligence by informing me that a.) Costco's shop does not have the proper "no-touch" tire equipment, and b.) whatever equipments they were using might've result in rim damages during the tire changing process. If I'm not compensated for the damages, next step will be spending ~$200 to have a lawyer draft a formal letter, send it to whoever-the-power-may-be, and proceed with small claims court if all else fail. |
11-23-2011, 12:41 AM | #12 |
Gunny
30
Rep 623
Drives: '07 E90 335i 6MT, 2016 F10 535
I had two of my wheels damaged after my first new tire installation at discount tire. I showed them the damage and they hired a company to repair the wheels free of charge. They did an excellent job. The damage was obviously from their machine and they apologized.
2007 E90 335i 6MT, ZSP, Nav, PDC, CA, Montego Blue, Terra Dakota leather, CDV, clutch-stop, E46 M Shift Knob, Logic HVI, JB4 PnP, MS 3" downpipes, Koni Yellow adjustable sport shocks, RE 12mm(f)/BMS 15mm(r) spacers, Blacklines, LUX 5.0 LED halo ring lights, DAEOS (Vista) harness, GP Thunder 7500k fogs, 35% sides-20% rear tint, matt black kidney grill, matt black 335i trunk badge
11-23-2011, 01:40 AM | #13 | |
9
Rep 338
11-23-2011, 12:10 PM | #14 |
Ex-Diesel Driver
63
Rep 2,000
I have had numerous bad experiences with Discount Tire, Belle Tire and the chain shops. If they are my stockers or winter setups, I'm not as worried. But for my summer wheels, I go to the indy shop that does my in between oil services. They charge twice as much, but never had an issue.
One piece of advice, always take pictures at drop off. Have the manager or service writer acknowledge the pictures. When they get back and they aren't as pictured, don't leave until you are satisfied. Sad that it is our word against theirs, but it has come to this. RANT OVER.
FS: HRE Center Caps http://www.e90post.com/forums/showth...post13972317l] |
11-23-2011, 01:22 PM | #15 |
BimmerPost Supporting Vendor
2045
Rep 25,989
It's definitely possible to mount and dismount tires without any damage to the lips of the wheels, we do it all day long every day. With that said though, some equipment is more prone to cosmetically damage wheels than others. I'd look for tire shops that use equipment that doesn't touch the wheel in the future.
VMR|Wheels | 714.442.7916 |
