2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions FENDER liner
      11-19-2011, 04:48 PM   #1
kaddu
Drives: 2011 528i (F10)
FENDER liner
Hi,
Having some bad luck with the car these days ....
I drove over white spilled paint on a freeway and the tires splashed it all over the inside of the front fender.
1. Does anyone know how to remove the front inside fender liner ?
2. I plan to try to clean the plastic part but not sure if there is a way to clean the fibre glass portion of it.
Any ideas on the two questions please ?
Thanks guys
Kaddu
      11-19-2011, 07:54 PM   #2
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
you are lucky. The rear uses a sort of carpet like material that is much harder to remove paint from. The front is a smooth plastic, and should be easier to remove paint from. I used graffiti remover and it worked just fine. It is in an aerosol can so I don't think you need to remove the liner, but you do have to remove the wheel.
      11-21-2011, 11:36 PM   #3
kaddu
Thanks. yeah I realized that. Suck ! Finally cleaned the plastic piece and ended up painting the rear with 3M black undercoat. Not a perfect match but I guess will look the same in few weeks of driving in rain. Barely concerned myself not replacing them for $ 200.
      11-22-2011, 12:27 AM   #4
XDEEDUBBX
XDEEDUBBX's Avatar
64
Drives: 535I
do the right thing (russell peters lol) you did the right thing. Thats exactly what I would have done.
5post
